Home > Maintenance & Modifications > Door bolt torque figure - (Now established as 15 Nm)
scotia
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Is there an official figure for torquing up the door bolts - can't find one myself?
Post #445994 14th Aug 2015 9:41am
ericvv
I just replaced all bolts, had asked both dealer and a Def specialist about torque settings. Best answer was from the latter, tighten it up, but don't overdo it. So unless someone knows figures here, common sense seems to order. It worked for me. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #446023 14th Aug 2015 10:49am
K9F
Eric is correct, direct cut and paste from Workshop Manual, no torque settings apart from 'quarter of a white knuckle'.... Thumbs Up
Installation
1. With assistance position door and fit but do not tighten
bolts.
2. Align door to body aperture and tighten bolts. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #446026 14th Aug 2015 11:03am
scotia
Thanks both of you.
Explains why I could not find anything. So too loose and doors drop or fall off and too tight and threads strip or retaining nut shears. It would be nice to know what torque the factory power wrenches are set to. Do you think Ryan would could find this?
Post #446036 14th Aug 2015 11:38am
K9F
Possibly Ryan could help but where would they get their setting from? Trial and error I presume! I replaced all my door hinges including the Safari Door with no torque figures and no issues whatsoever. Bearing in mind I am by nature heavy-handed I just used a little caution. If you are used to spannering just use the same principles. As they are all readily accessible it is no mither loosening them, realigning and nipping them up a little tighter should you find the door sags, they'll hardly fall off as you mentioned unless you don't use a spanner at all, forget to connect the door retaining bars/straps and the lock entirely misses the door striker? Just get on with it!
Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #446038 14th Aug 2015 11:48am
scotia
OK thanks again. I think I'll just let it remain a mystery - a factory secret as it were Snigger
Post #446045 14th Aug 2015 11:59am
scotia
Found the correct torque figure for all of the door bolts is 15 Nm Whistle
Post #446072 14th Aug 2015 1:42pm
ericvv
Post #446089 14th Aug 2015 2:35pm
scotia
Someone in the know Bow down
Post #446123 14th Aug 2015 4:24pm
munch90
I done mine with air gun Rolling with laughter
Post #446124 14th Aug 2015 4:26pm
ericvv
Post #446135 14th Aug 2015 4:56pm
ericvv
Post #446137 14th Aug 2015 4:58pm
Retroanaconda
You'd have to be pretty ham-fisted to shear off an M8 bolt or strip the threads in the nut inserts.
Just do them up 'tight' - it's only a door hinge!
Post #446139 14th Aug 2015 5:00pm
munch90
ericvv wrote:
At the same 130 Nm torque setting as for the wheels I guess. Laughing
Eric
I got torque select trigger finger Whistle
Post #446140 14th Aug 2015 5:06pm
scotia
Do what you will Banging Head
Post #446157 14th Aug 2015 6:06pm
