![]() | Home > Puma (Tdci) > MY15 110 Brake Issues |
trouble with abs cutting in isn't seen as a fault by the control unit , so no fault codes will be logged
the abs unit is seeing different wheel speeds , so its a fault with one etc sensors maybe losing its reading really it would need driving with wheel speeds monitoring while driving and see when it happens what speed readings you get at the time from each wheel |
CarlS Member Since: 10 Apr 2007 Location: Probably near you Posts: 148 ![]() ![]() |
Thanks munch90,
I'm hoping the LR mechanic will have a wheel speed monitoring system he can plug in on the road test. Wheel speed sensor fault hopefully......... The spawn of AndrewS 2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead 2016 Mini Countryman Cooper S All 4 2019 BMW R1200 GSA Rallye Sport |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
To get really technical it should be possible to Plug in an Oscilloscope capable device. e.g. Snapon Versus and then on probe each wheel sensor and see the read out. you should see a uniform pattern as the sensor goes past the ridges on the ABS ring.
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
I have the same issue with screeching brakes. Been back to the dealer once and about to call them up again. Mine has done just over 4k now and been in twice under warranty. No issues with abs yet though
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
My '15 110 has about 4300 miles (just under 7000 km) on it and has the same squeeling brakes. no issues with ABS/TC/LMNOP
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I wonder if LR have changed their brake pad supplier? I recently fitted new front OEM LR boxed pads and they started to squeal after a couple of hundred miles? The back of the pads also got a liberal coat of copper slip as did the piston fronts. As the op pointed out it only occurs below 10 mph which is annoying when driving around town. I think I will try a set of mintex pads and see how they go.
The ABS issue could be down to a sensor not being seated properly or a fault on the loom to the sensor. As it is so new get LR to fix it asap as the last thing you want is a single wheel braking at 70 mph especially if the fault is on the front axle. ![]() Plugging in a diagnostic tool will give live data to what is activating the ABS and if it is a wheel speed sensor you know we're to start. The below screenshot is of the Wabco D ABS unit fitted to my 2009 defender. This is not the type fitted to yours but gives you an idea of the available live data. ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Giving an up-date on Carl's behalf.
It would appear that the front brakes randomly apply themselves individually or both together. This can be felt through the steering wheel as the car pulls in the direction of the braking wheel. As you can imagine this is quite unnerving and very dangerous. Our dealer plugged their Land Rover lap top into the truck and went for a test drive, the braking issue was witnessed by the tecky and recorded, the data capture files have been sent to Land Rover. Yesterday whilst on a run to Hereford the front OS brake applied its self causing the vehicle to pull towards on-coming traffic, fortunately without consequence. Carl has now refused to drive the truck and its being recovered today to our preferred dealer. Coincidently as the arrangements were being made to recover the truck Land Rover responded to the data files they were sent. They requested that the vehicle is returned to the dealer to carry out further tests. 130's have feeling's as well you know ![]() |
That is a very worrying, and potentially lethal fault
![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 125 ![]() ![]() ![]() |
We had a member on AULRO with the same issue,it was the brake peddle switch. Pat
Faulty steering angle sensor is where i'd put money on
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 ![]() ![]() ![]() |
This has happened on mine but only at very low speed...like pulling out of a parking bay. Dealership has replaced the sensor - but the event was so random that it will take time to see if this was the problem. Also no fault codes.
Thanks AndrewS ![]() ![]() ![]() ![]() 2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead 2016 Mini Countryman Cooper S All 4 2019 BMW R1200 GSA Rallye Sport |
CRC@LandRover Verified Account ![]() Member Since: 25 Mar 2013 Location: Coventry Posts: 383 ![]() ![]() |
Hi CarlS
Thank you for your post. I am sorry to learn that you have been experiencing concerns with your vehicle at such an early stage in your ownership, please accept my apologies for any inconvenience and frustration that may have been caused. I note that you may have already sought assistance from your local retailer regarding your concerns and hope that they have been able to address your concerns to your satisfaction. However, should you require any additional assistance, please feel free to send me a PM with your details and I will be happy to help. Regards Ryan |
noriega Member Since: 15 Apr 2015 Location: Lugano Posts: 7 ![]() |
Got similar issues; the brakes are squeeling on my new MY 15 (5000km) Defender when going slow; further the ESP is cutting in very early when doing tight turns. Switching it off changes nothing, it still breaks the car at the same speeds when doing the same corner. Don't know if the issues are related. Dealer days that's normal... very annoying.
Cheers, mike |
