Home > Td5 > TD5 Water Temperature Gauge
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Hi all,
Wondering if anybody can advise?
My temperature gauge is working fine except the gauge doesn't illuminate when the lights are switched on.
I bought a LED light set, but couldn't find the bulb, so I'm wondering if it's a sealed for life LED affair.
Hope somebody can advise.
Andy
Post #445602 12th Aug 2015 11:47pm
Martin
Site Admin
Assuming it's a standard Td5 gauge then there is definitely a bulb, pushed into a separate holder on the back.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #445603 12th Aug 2015 11:54pm
ROBBONTHEROCK
Thanks, it is a standard TD5 instrument pack.
Looks like I'm stripping it out tomorrow agaIn Smile
Andy
Post #445604 12th Aug 2015 11:57pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
If it' like the speedo, 9mm socket on a small extension to reach inside from the back of the gauge, the bulb will holder will fit nicely in the socket (or is it 8mm?)
Post #445608 13th Aug 2015 12:39am
Martin
Site Admin
It's not like the speedo, the speedo is off compared to the others Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #445609 13th Aug 2015 12:40am
Martin
Site Admin
*odd  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #445610 13th Aug 2015 12:45am
rfkdemon
United Kingdom 2000 Defender 90 Td5 Silver LE Zambezi Silver
When you look at the rear of the gauge it is fairly obvious as it is a bulb holder with two terminals on, from memory it is a 286 1.2v bulb fitted from the factory.
What you may find is that if you cant see the red and black wires (from memory) going to the bulb holder then the bulb holder may have simply fallen out of the back of the gauge and if you are lucky it will still be plugged into the 12v supply.
Matt
Post #445635 13th Aug 2015 7:34am
Martin
Site Admin
You can see the bulb holder right in the middle on here:
2015 D90 XS SW
Post #445695 13th Aug 2015 10:30am
ROBBONTHEROCK
Sorry my bad.......
I confused the two gauges when I wrote my query up.
1) the clock looks like a sealed for life unit, ie no serviceable parts (eg bulb);
2) the temp gauge light is very easy to do....
Sorry my crap memory.....
So is the clock sealed for life?
Indeed the speedo also looks like it's a sealed for life unit as well.....
Ps changed the bulb on the temp gauge Wink
Andy
Post #445790 13th Aug 2015 1:53pm
Martin
Site Admin
Speedo bulb info: http://www.retroanaconda.com/landrover/200...formation/  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #445793 13th Aug 2015 1:56pm
Martin
Site Admin
The clock is "sealed", with LEDs on its PCB.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #445795 13th Aug 2015 1:58pm
ROBBONTHEROCK
Ahhh, many thanks.
Will ditch the LEDs then Sad
Andy
Post #446077 14th Aug 2015 1:57pm
CDN38
Coincidence, one of my my speedo bulbs went out today, so it was replacement time.
I changed the bulb without removing the gauge, rather just unscrewed the binnacle, tilted it up for access, and used a socket to retrieve the bulb. did try tweezers, but fishing around blindly was frustrating.
Correct socket size is 11/32, with 1/4" drive, guides in easily, grips the bulb nicely, just a gentle twist, and out it came. Insert the new bulb by placing it in the socket, gentle push in and twist.
Post #446974 18th Aug 2015 4:22am
