![]() | Home > Technical > Aircon grill surround bolt size? |
| Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002
Hi does anybody know the size and length of the 2 capped bolts in the side of the aircon grill surround as mine are rusty and I want to replace with stainless. Thanks in advance
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
Arent they a big self tapper screw
| RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038
Yes they are. 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
What size?
Thought so , maybe someone has replaced them with normal headed self tapper instead of big phillps headed
Just checked with a torch they are hex bolt heads with flange which bolt into a captive nut on a bracket inside the grill surround one on left side and one on the right?
Pretty sure ive never seen a normal threaded bolt , only self tappers , guessing someone has changed them before
| discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2543
Just recently replaced mine with A2 stainless posidrive pan head self tappers 6.3mm dia thread, 20mm long.
^^^^ yep sounds right
| Barney12 Member Since: 09 Jun 2015 Location: South West Posts: 744
I had the same issue. My local Indy had packs of the pozi's from Britpart (insert expletives about quality etc) for a couple of quid:
Same as here (first result on Google): http://www.rimmerbros.co.uk/Item--i-LL1548BP Strangely this is supposed to be a set for the grill but actually contains 8 of the pozi sized mentioned above. On my Puma grill these are only for the two side points as being discussed. I then have 4 smaller pozi's which run along the top edge. Not sure if the above helps but there you go |
