![]() | Home > Maintenance & Modifications > Clutch rattle |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20992
Probably clutch springs. That's my guess anyway.
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027
Turn the engine off in neutral and listen to the noise, then do the same with the clutch in its probably a lot less noise. If so its the clutch springs, mine has the same and has been for the last 10 months, just an annoying noise really 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
| 90def Member Since: 11 Apr 2011 Location: bedfordshire Posts: 98
Cheers for the replys glad its not a new clutch thanks Phil
| nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720
I've had exactly the same issue for months. Not got any worse than the day it crept into my life. I was thinking springs or could it be imput shaft bearing?
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
springs are part of clutch , so yes all new clutch needed |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127
Replace clutch ASAP!
Just done mine, just in time too, 2 springs were literally ready to pop out, and they started to chew up the clutch plate which could have caused untold damage if it had of let go! Don't ignore this noise...... Wanted, Forward Control Anything considered. |
| Dora Member Since: 12 May 2015 Location: South East Posts: 170
Yep, mine too.. Just had it and the Ashcroft input shaft conversion done at 89k. springs about to pop and shaft knackered!
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17974
Other way round - clutch in, noise. Clutch out, no noise. Clutch in = pedal up. Clutch out = pedal down. A widespread misunderstanding of clutch terminology! Eventually the springs will fall out and it will be much more than just an annoying noise. |
To most people including most car trade , if you said let the clutch out it would mean take your foot off pedal
so clutch out would mean pedal up |
Like I say, it has become a very widespread (and to me rather incomprehensible) misunderstanding. You let a clutch in to take up drive, you throw a clutch out to disconnect the drive. It has always been thus, since about 1873.
i know what mean , but most will see it otherway round
| Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178
Blackwolf- now that is really interesting! Probably not much use since we all seem to be dyslectic in regard to the use of the terminology. I had never thought of it the way you put it but you are quite correct! |
The same is true of gears - "in gear" = drive, "out of gear" = no drive. Less confusion with that though.
