![]() | Home > Technical > Td5 speedo in tdi |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
you need a td5 transducer and some 3 core cable to replace the tdi speedo cable.
![]() my youtube channel |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
Don't buy a Britpart transducer, lots of reports of them failing quickly.
everything you need to know here
http://www.retroanaconda.com/landrover/200...tdi300tdi/ My 109 thread my youtube channel |
It's a ubiquitous Econoseal 3 pin connector too
Rich broom Member Since: 26 Jul 2015 Location: Tiverton Posts: 78 ![]() |
Cheers chaps.
Shame I can't use the 300 TDI transducer as I have a few sat here |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2750 ![]() ![]() |
Technically you can, but you would have to re-program the speedo head's EEPROM to accept a different number of pulses per mile. I have also seen someone take apart the Disco unit and modify he rotating magnet to have more 'lobes' which effectively increased/decreased (I forget which) the number of pulses generated per mile to match what is required by the speedo head.
There's a good thread on LR4x4 where a couple of clever chaps reverse-engineered the speedo head and decoded a lot of the internal programming. |
That sound like a lot of
You're right, though they're closer to £70 now.
