![]() | Home > Technical > Weird temp guage issue |
Rob00 Member Since: 09 Aug 2015 Location: North Wales Posts: 42 ![]() ![]() ![]() |
Did find these today. One plug which has previously been cut off sat on lower engine just by chance it was still there as I have done around 1000 miles since I bought it. Other photo is a cable cut at both ends which is on a bracket on rear of gear box. ??
Also worth noting the truck was ownedby utility company so they likely had other things connected. Oh yes on checking engine it never seams over hot and fan seams to cut in fine. ![]() Click image to enlarge ![]() Click image to enlarge |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
I had issues with my CHT sensor easy and cheap to fix! 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Cool
Getting new one fitted tomorrow, so with a little look she will be fine after ![]() |
Still concerned as to what the cable is i have found cut at both ends which is on a bracket connected to the rear of the gearbox though?? One end looks single core (although not sure) and the other end after connector is 3 core???
Browny90 Member Since: 20 Jul 2015 Location: Derbyshire Posts: 183 ![]() ![]() ![]() |
the big cable that has been cut is a taco graph speed cable, So the truck would have had a Taco & probably a speed limiter fitted. you will see on the big cable's plug that it has locking wire and a lead seal, the seal will have a number on it, which is the taco centre which calibrated it.. it is safe enough to unplug and just get rid of, or just leave as is.. I would imagine that the other cables are either also from the speed limiter/ tachgraph or something similar that the utility company used. the one at the rear of the gearbox is definitely for a taco and has nothing to do with temperature. My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey ![]() |
Browny
You are a star, that makes perfect sense. You are right there is a locking wire on it, which is what i noticed first! I pulled the cbale further out to make a better photo. For future potential is there any value in leaving this on even though its not connected? I just wonder if i cut it nicely and blanked both ends off, would it potentially save anyone a great deal of money and time if they wanted to add this otpion in? I must admit i have already considered this for myself, so its trange it was there. Honestly you are great ![]() THe cable is two in the same, just different ends, so thats that issue sorted. Engine Management light came on again this morning, so this time i just ignored it. It did appear to go in a slight limp mode, but i kept driving and after another 120 miles it arrived in one piece. Just waiting on garage to call to hopefully get new CHT sensor fitted today. Thanks again. |
Anytime, I used to fit and calibrate Tacho's & Speed Limiters for Scania Trucks so easily recognised..
If I were you I would keep the plug on, but cut the cable all the way to the plug.. that way it keeps the cr4p out and doesn't really do any harm.. Good Luck with the cooling problem! My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey ![]() |
Got this one fixed. Fitted new CHT sensor on back of engine. Easy enough to do so did it myself and hey presto, no issues with temp guage or limp mode since.
