![]() | Home > Maintenance & Modifications > Rear CSW Seats removal: How to with pics |
good write up , but bolts are T40 not T35
t35 may work but your risking damage to the bolt t35 is quite a rare size and tends to be for tamperproof bolts |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648 ![]() ![]() |
Following my recent 'poll' thread on whether to remove the seats or not, this is a brilliant and very useful post!
Many thanks. ![]() Pete. ![]() |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2028 ![]() ![]() |
Just figured it out. You are right, it is a T40. My bit set are the hollow star bits and in those, it took a T35. I'll edit the post above 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol Last edited by RRUK on 10th Aug 2015 9:53am. Edited 1 time in total |
Bears Dad Member Since: 09 Dec 2011 Location: Aylesbury Posts: 43 ![]() ![]() ![]() |
Good job!
It was your thread and others Pete that spurred me to write it up. Many newer Defender owners want to do this but are not keen on DIY stuff, I wanted to show it can be very easy. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
![]() and just about to remove one of my seats ready for holiday to get bit extra room , I made a small shelf that bolts inplace of seat |
Munch90, you should post a pic of that, ideas for others are always handy. 2016 D4 HSE
if I could add my two pence worth to write up
wire brush bolt exposed threads and nuts under wheel arch and spray with wd40 day before ( or few hours before ) the exposed threads could be rusty and either seize and snap or damage threads in fixed nuts in arch/floor the threads in the fixed nut in the floor are not the best , when refitting the bolts make sure they screw in coulpe of threads by hand as there quite easy to cross thread |
Pete4810 Member Since: 26 Dec 2013 Location: London Posts: 9 ![]() ![]() |
Ive just done it - and to remove the seats took apx 90 minutes.
You will need the T40, and you should make sure the seats are returned to the folded position just prior to removing the last bolts. I now have loads of space in my 110 - prior to next weeks european road trip! |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
Thank you for the nice write up !!
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 ![]() ![]() ![]() |
Nice write up! I've found you get quicker with practice. Also, if you don't need a totally flat floor space then it's a bit quicker to remove the hinge bolts from the brackets holding the fold-down frames, rather than remove the whole bracket.
Last tip: a cut-to-size bit of 15 or 18mm ply makes an ideal load platform, and provides a bit of "security space" for any items you want to keep out of sight... ![]() Click image to enlarge This one is fitted with M8 captive bolts that line up with the holes through the arches to hold it in place. (See this post... http://www.defender2.net/forum/post424340.html#424340 for details if you're interested) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 ![]() ![]() |
Very useful guide, thank you
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2140 ![]() ![]() ![]() |
Many thanks to RRUK for this how to do it post ... very useful and easy to follow !
![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
