![]() | Home > Technical > Clicking/Clunking Noise From Driveline |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17878 ![]() ![]() ![]() |
Quite possibly the front (2 gear on a 2008) diff breaking up. If so, beware if it siezes completely since it will become virtually impossible to do anything except drive in a straight line. Very disconcerting and somewhat dangerous.
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 ![]() ![]() ![]() |
I have come to the conclusion that it is that. I took the wheels off, and turned both hubs to try and find anything. Both of sides feel the same, quite a bit of slack to take up before diff turns, and somewhat lumpy when you rotate it back and forth.
![]() I think I'll be using the 88" to go to work until I get my hands on a 4pin diff to go in! Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
An Ashcroft ATB is a cheaper and stronger option than a LR 4-gear diff.
A built one from Ashcroft is £642 all in, whereas a 4 pin standard is £587. However, the difference would make it worth getting the ATB anyway, but I would rather the ATB in the rear axle if I was only having one to reduce the small effect they have on steering (plus more effective there)... one in each would be better though
![]() 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
Am I correct in thinking that the 4 pin diffs are the same front and back? Because if so (and I know it's twice the work) you could put the rear diff in the front and the ATB diff in the rear.
No, the 110 and 130 Defenders have different diffs front and rear. Its a "Rover pattern" in the front, and a P38 in the rear. 90s have Rover pattern diffs at both ends, but they're 2-gear diffs at both ends.
4-gear Rover diffs are scarce and expensive 2nd hand. I have ATBs F&R and can say with complete confidence that I haven't noticed any effect on the steering (certainly far less than the effect of an utterly seized 2-gear Rover diff, which is 'interesting'). When I bought the ATB for the front (the only one I bought built up) a new fully built ATB with HD R&P was substantially less than the list price for front diff from LR. So either the Ashcroft diff has gone up, or the LR diff has come down since then! |
I seriously considered getting a built up ATB, however at £795 all up with VAT and delivery I couldn't justify that cost... So have just purchased a recon standard diff. Maybe I will regret it when the new one breaks at some point down the line!!
I will still be looking at an ATB for the rear once I've built up the Landy savings again! So, apart from the differential gasket and some Ep90, what else am I going to need for the rebuild. Drive flange gaskets, the ones between the swivels and the main axle (if I go down this method)? Thinking about having a bash at it myself, I've done a rear diff before but a bit nervous about the front as it's a much bigger job. Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
I seem to remember doing a write-up when I did mine.
The quick way: Remove front propshaft, jack front of vehicle so the front wheels are just off the ground (1" or so), remove tie rod (both sides) and disconnect drag link on n/s. Drain axle oil. Unbolt the swivel housing from the axle tube and withdraw the entire wheel/hub/swivel assembly about 2" from the axle, making sure you support the steering arm to prevent the assembly rotating on the hub and straining the brake hose. Repeat for other side. Unbolt diff carrier from axle, being mindful that it is fairly heavy. It will also have been glued in with about four tubes of sealant! Before installing new diff, inspect the inboard ends of the halfshafts for damage through the hole in the axle (my failure to spot a damaged spline cost me an ATB!). Clean the mounting face for the diff (this is the hardest and most time-consuming part of the job, the old sealant is really hard to get off). Install new diff using the recommended sealant - there's no gasket.. Slide the hub assemblies back in and bolt up. Reconnect everything, fill axle with oil, put tools away. (Editted repeatedly for spelling! Oh, how I hate tablets with their poxy keyboard things!) Last edited by blackwolf on 11th Aug 2015 10:39pm. Edited 3 times in total |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
Swivel oilseal behind swivel
Swivel large oil seal Gasket for swivel ball Optional wheel and swivel bearings while your there. One shot grease. Stub axle gasket Stub axle inner oil seal Hub inner oil seal Split pins for track rod ends? Instant gasket blue stuff Opportunity to paint up your swivel housings and clean emup. Drive member gasket I'm doing the reverse and building my first front axle at the moment! Put the diff in last week and next are the swivels etc. |
Can so tell you've done that before! Nicely done |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I will add to BW's write up by saying that you will also need to remove the offside ARB mounting if fitted to allow you to completely remove the final drive.
Good point I don't have ARBs on mine so this wasn't an issue for me!
Yes, rather more times and on more vehicles than I really wanted too, but you do get better and quicker with practice. Takes about 3 hours including putting the tools away now! ![]() |
If you are replacing just the diff you will also need a DTI gauge to set the backlash along with some engineers blue to check the gear mesh.
