Home > Wheels & Tyres > My new wheels arrived!
fumiyasu
 1999 Defender 110 Td5 SW Santorini Black
New blindos arrived, can't wait to put them on Mr. Green
Post #443449 5th Aug 2015 6:03pm
Darcy Fairfax
England 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Nice! Love Blindo wheels Thumbs Up
Post #443466 5th Aug 2015 6:29pm
AndyS
Get yourself one if these: 27mm Socket from Halfords. It has a plastic outer edge so you don't mark the wheels when tightening the nuts and is a bit longer to help you get your torque wrench on without needing an extension.
You may also have problems getting them balanced due to the large hole in the middle of the wheels so ask your tyre supplier before you buy because it's a right PITA lugging wheels around to tyre fitters tying to find someone to balance them. Other than the huge weight of them and lifting them onto the hub, they're superb. As was said to Indy "You chose wisely". Rolling Eyes
Post #443470 5th Aug 2015 6:43pm
London 52
United Kingdom 2005 Defender 90 Td5 CSW Belize Green
Great choice and really good advice from AndyS on the The Laser Alloy Car Wheel Nut Socket 27mm.
I had my tyres (265/75R/16 Cooper STT) fitted locally, the fitter had never fitted and balanced tyres to such heavy alloy wheels before.
Post #443486 5th Aug 2015 7:47pm
jimbob7
Looking at getting a set for mine.r.e balancing,did they use stick on weights or knock ons? I notice they use knocks ons for std LR alloys and they are spot on and any recommendations where to get em? Pov.spec,ftw. 2006, 110,TD5.
Post #443510 5th Aug 2015 8:47pm
Very nice, make sure they are stored securely. (No doubt they are anyway.)
Otherwise new wheels have been known to go walkies all by themselves. Rolling Eyes
Thumbs Up
Post #443514 5th Aug 2015 8:57pm
fumiyasu
Was thinking about protective socket right now actually as I look at them in front of the TV.
I think my supplier should be OK as they sell a lot of bfg and other off road tyres.. Fingers crossed..
Post #443515 5th Aug 2015 8:59pm
fumiyasu
Nice truck, my td5 used to be green and white roof actually.
Post #443516 5th Aug 2015 9:01pm
London 52
Mine were balanced with stick on weights, lots of them lol
Post #443517 5th Aug 2015 9:01pm
London 52
The Belize Green and White roof are a bit old school and not too every ones taste but I think with the Black Blindos all looks well.
Post #443520 5th Aug 2015 9:05pm
fumiyasu
Mine was coniston green. White on green is definitely the classic colour for a defender. Its one of the colour schemes that I want to go back to at some point.
Post #443525 5th Aug 2015 9:15pm
AndyS
Yeah, mine too. I went over those with black duck-tape to make sure they stayed stuck while I was fitting them.
Post #443527 5th Aug 2015 9:18pm
London 52
Ha Ha, I did the same just in case lol
Post #443532 5th Aug 2015 9:22pm
They look good, might need one of those myself soon.
I also found a good alternative from Sealy, cheaper too via Demon Tweeks on eBay.
Here: http://www.ebay.co.uk/itm/Sealey-Alloy-Whe...20f72c89c1
Post #443539 5th Aug 2015 9:44pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
That one is also available from Halfords, but slightly more expensive http://www.halfords.com/webapp/wcs/stores/...;langId=-1
Interestingly Halfords say that as it is a thin wall design specifically for wheel nuts, it is excluded from the lifetime warranty. But they don't have the same info about there own brand. The Sealey seems to be plastic lined inside and out which would explain why the metal wall thickness is reduced. I t isn't obvious (to me anyway) whether the Halfords own brand is different?
Post #443544 5th Aug 2015 9:58pm
