![]() | Home > Puma (Tdci) > fault codes |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Here you go:
P167b O2 sensor heater circuit (bank 2 sensor 3). P1402 Exhaust gas recirculation metering orifice restricted. P0404 Exhaust gas recirculation "A" control circuit range/performance. P1103 Mass air flow sensor in range but higher than expected. P0100 Mass or volume air flow "A" circuit. P0606 Control module processor. hope it helps.........and its dgardel the one to thank, find all the fault codes here http://www.defender2.net/forum/topic3432.h...ault+codes Last edited by Lorryman100 on 4th Nov 2010 9:07pm. Edited 2 times in total |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
Daniele has a list of all the codes that you can download http://files.me.com/daniele.gardellin/vbutqe
![]() 2008 SWB Truck Cab 1952 80" Soft top |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
ok cheers do u no if any of them are really to worry about ?
cheers steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
looks as if you have gone too small on the egr blanking plate hole. If you just reduced down to 12mm and the problems started go back up to the last size, clear the fault codes (guessing you have a reader because of the fault codes) and see if the faults re-occur. Also read this post
http://www.defender2.net/forum/topic3115.html |
the light come on every month or so ?
so it doesnt worry me to much but long as it isnt anything else cheers for your help steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
