![]() | Home > Td5 > Where to hookup compressor leads? |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 349 ![]() ![]() ![]() |
Hi,
silly question maybe with an obvious answer to most of you, but not to me: where would I hookup my compressor leads in a quick way? I don't really want to hook it up to the battery directly (it's under the seat, no Anderson plug or similar, easy connection fitted) so I was hoping to find a good place somewhere in the engine bay or someplace else. As I'll be using aligator clamps, I was thinking of using the engine-hoisting-eye-thingy, but where to place the other lead? (I plan to buy the twin cylinder compressor from Paddock's http://www.paddockspares.com/pm982-twin-cy...00gbp.html) Thanks! Defender 130 HCPU Td5 MY2000 Last edited by RoadForce on 5th Aug 2015 10:18am. Edited 1 time in total |
^Link doesn't work.....
Many of the compressors come with a cigarette lighter adaptor and you simply plug it in there. It really depends on the current draw of the compressor and if the circuit will cope. If it's the 30 amp one I suggest you fit an Anderson connector or something similar to your seat box and hard-wire it in with adequate fuse/circuit breaker protection as the simplest one-off solution. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
There is no amperage details for your link the 'PM982' but the 'PM981' which is a similar compressor has a current draw of 30 amps which the cigarette lighter will not cope with.
Most certainly you will either have to connect directly to the battery or fit an Anderson type connector to use these items. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17874 ![]() ![]() ![]() |
I have seen cigarette lighter sockets melt long before any fuse has blown. I woudl never plug any compressor into one.
Connect directly to the battery or a properly wired socket of adequate capacity (probably and Anderson, though alternatives exist). |
I am overseas right now so I cannot check with my car, but can't I just use the engine lifiting eye and e.g. the starter motor's power connection to hookup the aligator clamps, or is that out of reach? Defender 130 HCPU Td5 MY2000
^^ The battery's a lot more accessible, I think!
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6013 ![]() ![]() ![]() |
Two choices, lift battery cover or Anderson stlye connectors. 1999 Defender TD5 110
All right all right, I give in...
