![]() | Home > In Car Electronics > Puma speaker/Radio upgrade |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
4" Speakers only good for Mid & Hi tones even the best wont give the lows you wish for
| Jamesjames999 Member Since: 16 Jul 2015 Location: Warwick Posts: 15
Thanks for you're reply, yes i am aware that 4" speakers are very limited on the bass side but what do you recon i am going to get the best results from?
Also would a flat sub be easy to install? thanks James |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
Not much extra bass yo get but you can improve some mid range and quality.
13cm is possible providing your happy to cut the dash. Personally I'm not sure if I like the look of 13cm in a Puma dash. Looks a bit like Beverly Hills women. |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
5.25 inch speakers fit with 25mm MDF spacer rings and minimal cutting.Lower dashboard is made with 5mm foam 1mm (approx) mild steel. Pov.spec,ftw. 2006, 110,TD5.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge From experience Upgrade the 4" to Crossover Focals inc tweeter upgrade Then 6x9 fitted Midships in custom Box & Focal Sub powered by an appropriate amp Don't forget ample sound deadening |
"Don't forget ample sound deadening
Very true, perhaps THE most effective upgrade. |
Thank you all for the feed back, and do the Tweeters make a bige difference? where did you purchase for focal tweeters?
Also my Defender so only has the dash speakers thanks james |
| Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482
James,
If you don't already have tweeters they make a massive difference, make the sound feel like its coming from the screen rather than your knees, also they allow the driver to concentrate on the mids and some lows and the tweeters just the high's. If you have the stock tweeters then upgrading them and the stock speakers still makes a good improvement in sound quality. Well worth installing a good set of components. Sorry ignore me im clearly having a senior moment at 40!! getting confused with another thread about tweeters. I have focals 100 krs but they certainly do not increase the bass on their own the fronts are all about sound quality and bass is picked up by a sub on the cubby or elsewhere depending on where you want to put it. Last edited by Snowy90 on 4th Aug 2015 11:17am. Edited 1 time in total |
| Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5893
Doesn't the bass rattle the pannels so much they drown out the music?
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Not if you use sound deadening material
Ken how did you fix down your 6X9 speaker pods to stop them moving in emergencies or any other time.
Ta Chris |
Sound deadening I,proves the sounds anyway, not only does it reduce vibration.
It reduces engine noise and improves sound quality to boot on top of that for this very reason. Where possible any speaker / sub that produces good bass should be secured well to a solid part of the body. Not always possible but should be an aim to make. |
After three 4 hr stints driving through Italy over our long weekend just gone, I think my wife is very convinced by sound deadening!! So it will definitely be going in over autumn. Now I just need to convince her of the validity in a Bowler Stage 2 tune....
"Now I just need to convince her of the validity in a Bowler Stage 2 tune....
Increases MPG of course. |
