![]() | Home > Maintenance & Modifications > Dog Guard fitting in a 90 CSW: Help! |
consumerize Member Since: 27 May 2014 Location: Berkshire Posts: 121 ![]() ![]() ![]() |
I have this mine. its a bit fiddly until you work out where stuff goes. The bottom goes behind the bulkhead removal bars. but in front of the bracket. pictures here showing the left hand side looking from the back.
![]() Click image to enlarge The top section goes agains the reader side of the bracket, screwing in from the front. ![]() Click image to enlarge The bottom of the top pic sits on the bottom piece, forward of the screw brackets. ![]() Click image to enlarge Do everything up real loos to start, then tighten it up. If all else fails take the brackets that are in there out, and use the proper ones. |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038 ![]() ![]() |
I just don't see how you've managed to put the dog guard in front of the bracket on the wheel arch and yet at the same time behind the tubular bar.
In this photo below you can see that both in mine are in line with each other. This is why I can't get it to fit. ![]() Click image to enlarge 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
