Home > Maintenance & Modifications > Headlight cleaning system
ericvv
Looks promising for clearing LED headlamps which do not really warm up from snow in the winter.
From the German language website it looks like the item is commercially available already and ready to be installed. Guess the English translation has not been updated yet.
Wonder if it also works for a SVX front, need to check.
Eric
http://www.entreq.de/media/uploads/20150203_130100.mp4 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #441573 30th Jul 2015 5:36am
mk1collector
That's just the radiator that's sprung a leak Ray
My build thread
Post #441624 30th Jul 2015 9:47am
dgardel
Italy
Re: Headlight cleaning system
Eric
could you post the link? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #441652 30th Jul 2015 12:48pm
ericvv
Daniele,
Go to Entreq website. Click on:
- Werkstatt
- Beleuchtung und Scheinwerferreinigung
- Scheinwerferreinigungsanlage Land Rover Defender
The price is €589 including VAT and installation at their workshop. You can not just order the item for installing it yourself. I should be at Entreq again later this summer for another SVX job, so hope to see the item then.
Best, Eric You never actually own a Defender. You merely look after it for the next generation.
Post #441675 30th Jul 2015 3:05pm
SailingTom
Headlight washers I'd say are just a waste of water and dont even work on cars designed for them effectively.
Would be the last thing i'd want to fit, although was tempted to get a genuine land rover defender kit for one of my others, but only because it was unusual.
Post #441676 30th Jul 2015 3:23pm
ericvv
Agree they don't do much for cleaning, but was thinking more about removal of accumulating snow from LED headlights which do not heat up enough to melt it. From what I see in the movie, that would likely work. This snow accumulation on LED headlamps has been well reported on here. Now...., I do not drive in the snow.... Cool You never actually own a Defender. You merely look after it for the next generation.
Post #441684 30th Jul 2015 4:10pm
munch90
Hotshot and standard washer jet would do it ok for melting snow etc
Post #441739 30th Jul 2015 8:08pm
dgardel
Italy
Agree at 100%.
Hotshot should be the best solution for de-icing the LED headlamp...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #441767 30th Jul 2015 9:33pm
dgardel
Italy
I also think that the installation on the SVX could be a problem due to the shape of the headlamp surround
IID Pro MV License
Post #441772 30th Jul 2015 9:43pm
munch90
Plenty of washer jet styles to choose from
External washer pump and a hotshot , should be fairly easy to do
jet like this maybe
eBay Item No. 261651424159
Post #441780 30th Jul 2015 9:58pm
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
Having read this link, it set my mind to solving yet another problem i never knew i had.
Couple of Waher jets from Halfords, £1.99 each. and a bit of pipe.
Fashioned a small bracket with a Wickes bracket bent into shape. and bolted to my light guards
Connected it to my rear wash jet pipe, as never use it.
Needs a slight adjustment to line up, but seems to work like a charm. Combined cost less than £10.
Post #442502 2nd Aug 2015 7:27pm
