Home > Puma (Tdci) > tdci gear change issue
Page 2 of 2 <12
Happyoldgit
As Blackwolf says they are all different* out of the factory but there's generally a knack to getting the best out of the 2.2 gear change, it's still early days so personally I'd stick with it and try adapting your driving style as the vehicle does not have a particularly modern transmission and still has it's inherited quirks.
*Caterham old chap, the well known 2.2 rev hang feature requires quite a different input from the pilot as compared to the 2.4 Wink Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #441153 28th Jul 2015 7:29pm
Martin M
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
bob neville wrote:
Hi Martin
The 2.4 and 2.2's are different in the gear changing area due to the rev hold on the 2.2 to harmonise the change.
First thing, when changing gear do the normal thing of foot off the accelerator and depress the clutch, don't hold the throttle down !
Secondly try going to higher revs in each gear, 2500 is a good place to start. When you press the clutch down you will notice the revs hang despite removing your foot from the throttle. After a few seconds you will see them start to drop. On my vehicle I tend to push 2800 revs drop the clutch, put into the next gear and wait for the revs to reach about 2000 and then release the clutch.
As all the vehicles are different you will have to try to find the correct revs with a bit of trial and error.
It sounds complicated but once you have mastered the technique the changes become very smooth.
After 40 years of driving manual vehicles it took me a few weeks to master the 2.2 gear change but well worth it in the end Thumbs Up
I should add that once you are confident with the rev hang you can actually change up through the gears without applying throttle when releasing the clutch and there is not jerkiness or kangarooing - well you can in mine !
Bob
Thanks Bob force advice will try and let you know how it goes but I absolutely love the vehicle wished I'd bought one years ago
Post #441154 28th Jul 2015 7:35pm
Martin M
Thanks again for the advice will try a few different styles but that's why I bought it really just love it only had it a couple of days and only a short drive in it thought that it would be driver error. Wasn't expecting a modern feeling vehicle in fact would have been disappointed if it was like driving a modern vehicle just needed a bit of advice from more experienced members. That's the other reason for buying the landy everybody is so helpful and no daft one upmanship
Post #441156 28th Jul 2015 7:45pm
Happyoldgit
....just don't ask for opinions on which are the best LED headlights to fit lol Wink Steve.
Post #441157 28th Jul 2015 7:49pm
Martin M
Not even started buying yet as only took delivery on Saturday but it is that kind of vehicle everyone reflects the owners personality everyone you see is different will pm you when I get to led lights as you should be expert by then
Post #441160 28th Jul 2015 7:55pm
Happyoldgit
As you will see there are others who have a lot to say on that particular subject so best ask them, a pair of uprated bulbs are good enough for me. Steve.
Post #441173 28th Jul 2015 8:29pm
Martin M
TDCi Guy wrote:
Hi Martin, the gear change takes some getting used to if you aren't used to driving one. I was the same when I first got mine, now (the majority!) of my gear changes are silky smooth.
On a different note, are you from Leigh Lancs? If so I'll keep an eye out for you, it's not a big place. Thumbs Up
Hi Bern out today first real drive in her she's fantastic most of the time rest of the time like a marriage it's my fault lol
Post #441526 29th Jul 2015 8:31pm
Martin M
Hi everybody thanks for the invaluable advice first time out in her proper tonight she's fantastic like a marriage when it's good its good but when it's bad it's my fault lol will keep posting as now need more stuff lol like women with shoes
Post #441528 29th Jul 2015 8:35pm
Martin M
blackwolf wrote:
Martin M wrote:
Also think that maybe driving it too gently as I am short shifting at just under 2000 rpm think it needs a bit more pedal going to try tonight but it feels like slack in the gear train so when I change up the van feels like it bouncing forward and backwards
Excessive slop and backlash in the driveline is another well-known Puma problem. There are many places in the driveline where slop can develop, but the halfshafts and drive flanges are notorious. If you park on a level hard surface and apply the handbrake, see how far you can push the vehicle back and forth, and listen for clunks and noises from the hubs and axles. The transfer box, the clutch, and to an extent the infamous output adaptor shaft can all also contribute to this, so after the first test, put the car in gear (with the engine stopped), release the handbrake, and then see how far you can pucj it back and forth.
Some movement is to be expected, but it shouldn't be much. A vehicle as new as yours should be fine, but there have been some which are not well assembled, and there have been case of accelerated wear, so it is worth a check.
You can be gentle with a Defender too - you don't have to drive it as though you're wearing wellies!
Thanks blackwolf tried everything you advised but simple answer to problem my lack of defender driving experience been out today in her sweet as a nut a little more rev and a little more time shifting as sorted it but again thanks for your invaluable experience that's the other reason for buying her it's like joining a like minded club
Post #441531 29th Jul 2015 8:41pm
Page 2 of 2 <12
