![]() | Home > Series Land Rovers > RIVET GUN for SOLID RIVETS |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Keith Wadsworth, from Wadsworth panels sells them.
Google his name, not much to buy, and do a great job. Although you do have to go careful with them! I also have a manual one for hard to reach areas, looks a bit like a g clamp. A forum member on the LRSOC makes them, Bob Jones. They are not cheap, I paid £100 for one of his, but invaluable if restoring one. Hope this is of help ![]() Wanted, Forward Control Anything considered. |
Here is the sort of Finnish you can expect to get.
All the cappings replaced on mine. ![]() Click image to enlarge ![]() Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Ian,
Many, many thanks for the information. Excellent job you've done there. I wonder whether anyone has taken the pop rivets out behind the Defender door and replaced them with solid ones? At least they wouldn't rust! Thanks again Ian ![]() ![]() |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
Try this supplier, not cheep - http://www.aetools.co.uk/product-rivet-squ...nd-901.php NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17951 ![]() ![]() ![]() |
The tool you require for economically cold forming aluminium alloy rivets is called a rivet snap and is widely available. Type "rivet snap" into Google and you will find many. They are not expensive.
A rivet gun is only needed for hot forming steel rivets, such as when making rivetted boilers and other similar structures. Rivet guns are hard to find and very expensive. |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 264 ![]() ![]() ![]() |
i visited keith wadsworth a couple of years ago and bought the tool. It fits in my air-chisel and although i've never used it it looks easy. 1953 80"
1987 mini city e 2011 90" |
Not that easy when fresh paint is concerned.....
![]() Great bit of kit though. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 ![]() ![]() ![]() |
Hi Guys,
Thanks for bringing this up. I have this job to do in a few places on my S1 so will check out these tools.Cheers, John. 2.2 90 XS 88" Series One Old Norton ![]() Minerva |
