Home > Maintenance & Modifications > Installing tweeters in dashboard 2010 defender
Aäron
Spain
Hello,
I am new at this forum and i own a defender 110.
We live on the south coast of spain and 80% of the roads around the house are dirt roads.
I have only the two speakers under the dashboard and i want to put in the little tweeters on top.
Can anybody tel me how to install them.
Thanks!
Aäron
Post #44083 1st Nov 2010 11:50am
MK
http://www.defender2.net/forum/topic3919.html?highlight=lanzar
Cables are hanging inside so just P&P
Thumbs Up Puma 110" SW
Post #44084 1st Nov 2010 12:10pm
Aäron
Spain
Thanks!
But how do i remove the speaker covers from the dashboard?
Thanks
Post #44097 1st Nov 2010 6:12pm
MK
NICELY WITH A TINY SCREWDRIVER OR SIMILAR Puma 110" SW
Post #44100 1st Nov 2010 6:27pm
jerseyman
Re: Installing tweeters in dashboard 2010 defender
Aäron wrote:
Hello,
Aäron
Hi Aaron, I have an '02 TD5 Tomb Raider in Canillas De Albaida.
Toot if you see me
BTW What LR Agency do you use?
Brian
Post #44239 3rd Nov 2010 12:20pm
Aäron
Spain
Hi Brian,
what a beautiful roads you can drive around here he.
I use Sertasa in Malaga.
Aäron
Post #44258 3rd Nov 2010 7:13pm
I fitted tweeters into my headlining (td5), up by my right ear and my passengers left ear.
makes the sound much crisper. nice! mi gusto mucho!! Mr. Green
Post #44356 4th Nov 2010 10:23pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Topic Hijack !!! Razz
Thumbs Up
MK if you're reading this, or anyone else, where are the cabels hanging ... I've been checking and I can't seem to find any cables on mine Crying or Very sad ... My DC did not bring radio or anything, could that be the reason?, or do I have to look better ?!! Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #48904 17th Dec 2010 11:38pm
MK
NOt sure. Mine were just under the fake cap. Can not remember the colour nor the plug type. Had a look to the manual and did not mention anything important. Not sure if you need a crossover. Any radio (or google) store should know.
Did u get my PM sent sometime ago?
MK Puma 110" SW
Post #48907 18th Dec 2010 1:04am
lrmaniac
MK
No! Razz
It's not an easy place to take a look ... but I could not find any wiring ... I'll take a better look later on ...
Thank you! If I can't find it, I'll have to pay someone to fit mine ... Neutral Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #48912 18th Dec 2010 10:03am
Markh
England 2010 Defender 110 Puma 2.4 XS CSW Java Black
Images from my install,
removed the factory fit speakers and fitted my own set.
Remove, speaker cover (with tool shown, got this with my mobile phone car kit - very useful), remove main speaker in dash below, weight cable from new speaker and lower through the dash and connect into the Left/Right on existing main speaker and put back together...
Works a treat. Factory fit tweeter has built in cross over, my new speakers had a separate box but makes no difference
Mark "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #48928 18th Dec 2010 5:32pm
lrmaniac
my problem is that my car did not bring factory tweeters nor speakers and radio! .. I now have a radio installed and speakers ... but want a set of tweeters ... can't find the wiring - probably it's not there! - so I'll have to set up the wiring ... Razz Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #49011 19th Dec 2010 2:55pm
mse
No its likely they have managed the loom so the connectors are wrapped up with the main loom - so you will need to go hunting. Mike
Post #49013 19th Dec 2010 3:26pm
Markh
My was factory fit so easy to get to the loom, but the cables are only a spur off the main speaker feeds anyway, not separate feed from the head unit. Most ISO head units only have 8 feeds for speakers 4 x pairs i.e. 2 front and two back. Tweeters are not cabled separately.
Its the cross over that takes the output from the main head unit and reduces the frequencies down to just be those in the range of the tweeter.
Therefore take the feed from the Left/right into your main 10" speaker, and connect directly to your cross over and then on into the tweeter or if the tweeter has built in cross over (like the factory fit tweeters) just direct from the LR 10" directly to the LR of your tweeter
It should just work, you don't need a separate feed or need to find the loom cables ..... "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #49016 19th Dec 2010 4:14pm
lrmaniac
Fitted a pair of tweeters (Hertz - cost me €30), conected them from the speakers and fitted with hot glue under the existing lid - can't see that they're there. and the improvement in the sound is huge!
Next step, subwoofer and rear speakers! Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #51518 7th Jan 2011 10:49am
