![]() | Home > Puma (Tdci) > Diesel Additives and Oil Additives..... Thoughts? |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
Dont think they would make it if it damaged anything !
will it do any good is another question ! 2 stroke oil ? |
| tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54
Hi expatRob,
Using additives has proven to work. I use Forté Diesel conditioner every 2000ish Km and Forté Turbo cleaner every 3000km. Using it once a year won't do anything, you gotta use it on a regular basis. Keeps all internals clean which expands the lifetime of your engine and makes it run more efficient. One off the biggest benefits though is it eliminates algae from forming in the diesel tank. Oil additives I'm not to sure, when you do some research on them they seem to work very well however i'll just stick with high quality oils. |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Algae in diesel tanks? What is all that fuzz about here regularly? Over the years I have owned many diesels myself, and today I know, as we all do, a gazillion diesel drivers, and I never ever heard about any such problems. I also do not know anybody who uses such additives these days. Is this maybe a Defender diesel tank specific problem again?
My dealer surely is very clear on this, the Puma engine is made to run on diesel, nothing else is needed. The SVX never had any problems with diesel fuel alone for close to 80k km now, but admit, for many years I use exclusively BP Ultimate diesel with zero biodiesel content. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Stick an endoscope in your diesel tank and see for yourself mate, diesel algae is an issue affecting all diesel vehicles, there is a reason there are companies designated to flush diesel fuel systems. However you will only get affected by the issue when you run your tank dry and the algae forming on top of the diesel enters the filter. BP Ultimate (which I run as well) pretty much has the same affect as additives and this hosts several additives as well.
Every diesel engine is designed to run on diesel, such is the human body designed to run on water, does not mean you do not function better when adding some beer. Same counts for additives. The engine does not need it, but will sure help the engine stay clear from diesel sludge etc. quick note, just because you never experienced an issue first hand does not mean it is non existent |
Haahaha Touché, but that is more of a Heineken issue than yours I believe
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Only place I have heard of it being an issue, and then it was a very expensive issue, was with the emergency diesel generators located on offshore gas platforms. Engines were only run extensively during annual shutdown and so diesel stayed in tanks for many months. |
| expatRob Member Since: 24 Feb 2015 Location: Frankfurt Posts: 58
I have used Liqui Moly Diesel fuel additive x 2 tank fulls and the engine is running much smoother. Thanks everyone for your input.
| Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
Contractor came into our office today and informed us that his diesel car has just passed 200,000 miles on the odometer. It runs on whatever brand of diesel is available when he needs it, gets a regular oil/filter change and is as economical now as it was with 20,000 miles on the clock. He doesn't use any additives or special treatments - so I think I'll follow his lead.
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Whatever suite you.
I've worked out it's cheaper for me to put in Shell super dooper (whatever the silly go faster name is) than supermarket fuel. |
| cozz Member Since: 15 May 2013 Location: nottingham Posts: 548 |
because of increased MPG ? |
| Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170
Sounds like an old car built before 2000 ... they have been robust indeed. |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
Puma 2.2 with the dpf's' might not like 2 stroke
Like Eric, I just use BP ultimate or shell v power diesel now |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044
I could recommend Millers: http://www.ebay.co.uk/itm/Millers-Oils-Die...xyJX1TF1Ru
Opie is a forum sponsor with discount too. Boosts power, smoothness and gives everything a good clean though especially the injectors. I don't use it all the time, though you can, but I was surprised how good it was. Just a bit of a pain to do every time you fill up but hey ho. EDIT **** APOLOGIES WRONG LINK ADDED ORIGINALLY. Last edited by custom90 on 24th Oct 2015 1:25pm. Edited 1 time in total |
| All times are GMT |
