Home > Puma (Tdci) > Leaking seal
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Leaking seal
Why can't landrover fit a full length seal between the bulkhead and windscreen mine has roughly a 2 inch piece at each end before a the main bit
It's a joke considering it Censored water in through there
Not even two months old Sad
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #440518 26th Jul 2015 8:03pm
munch90
As far as i know it should be one length, sounds like its made up of bits
does it come on a roll in factory and you've got a bit off the end of roll
Post #440524 26th Jul 2015 8:32pm
big steve
Not sure but it's not the first defender Iv seen like it but after the rain we have had it really does come in 2015 2.2 tdci hardtop xs
Post #440528 26th Jul 2015 8:40pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Makes me wonder if JLR employ a team of people dedicated to finding ways of annoying the Censored out of loyal customers!
Post #440575 27th Jul 2015 12:50am
Eau02467
Mine is the same, need tho change it but think it's a massive job. May try to smear a thin layer of clear silicone over it n see if that helps
Post #440587 27th Jul 2015 7:08am
munch90
I cant believe anyone thinking its ok to have the window seal made up of bits
what year defenders are like this ?
all mine have been one piece and any ive looked at have ( not that I make a point of looking at window seals !! )
Post #440600 27th Jul 2015 8:53am
familymad
It's a warranty job. Seal should be one piece.
My TDCI went in for 3 weeks to the body shop and they took the roof off and applied a new seal. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #440632 27th Jul 2015 11:19am
big steve
It's 2 months old looked at 3.2 tonight which is 08 and that had the same but the seal is about 3mm thicker or not been squashed so much
Post #440792 27th Jul 2015 8:31pm
nitram17
Its maddening mine has a join about 2 inches from one end so its in two pieces...the passenger side is about 6-7mm thick but the other end is about 3-4.....is it true it has to be in one piece ..have you got that from landrover?Who ie the bloke on here who represents landrover perhaps i could get the sp from him!
Post #447339 19th Aug 2015 1:04pm
familymad
Part number is FAJ100020
LR one piece. Do a search for it. Have replaced 2 in last year. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #447344 19th Aug 2015 1:18pm
nitram17
thanks FM..did you do it yourself?So forthe need for a sub �5 part the landrover Censored are going to have to lift of the roof and replace the seal..What a bunch of ************* Evil or Very Mad Evil or Very Mad
Post #447347 19th Aug 2015 1:27pm
familymad
Yes. Need a couple of mates to hold the pressure on the roof to keep the gap open but after getting retaining brackets off, less than 30 mins on a CSW 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #447348 19th Aug 2015 1:29pm
pob1968
If you want to "bodge it" try plumbers gold from ever build. It is like silicone but much stronger and can be applied if the area is not dry. It is brilliant stuff. Go for clear of course. I am not trying to sell this myself ( I can but that's not why I'm posting this reply)
http://www.everbuild.co.uk/plumbers-gold
You can pick it up from a few places. 110 Hardtop
Post #447365 19th Aug 2015 2:18pm
ZeDefender
After LR dealer repeatedly Censored it up, I changed the foam tape with the help of my sons (65 kg each) to sit on the roof corners whilst re-tightening. I also used butyl tape (previously used as a temporary fix) to make a secondary permanent seal. No leaks since 1 year Thumbs Up Tell someone you love them today because life is short.
Post #447377 19th Aug 2015 3:05pm
nitram17
Does anybody know whats tha reason for the foam tape in the first place..there must be a better sealing medium out there?
Post #447378 19th Aug 2015 3:11pm
