Home > Technical > clutch / box
Page 2 of 5 <12345>
Caterham
Rumbling on braking has gone, vibrating at about 53mph has gone and did think the clunking had gone but unfortunately not! Crying or Very sad
There's a general feeling of it running smoother but not clunking not completely gone. Going to try and get A frame ball joint swap this week hopefully and see if that sorts and if not then in my eyes there's only two things it could possibly be;
The clutch
Or (and granted this is clutching at straws)....the prop. Where the prop extends this is initially stiff / sticks then moves smoothly freely but should it stick? And more to the point would it make any difference?
Just while I think incase this gives anyone a clue as to what the problem could be....when moving and changing from neutral into gear it like I've not depressed the clutch far enough and it's a slight struggle to get it into gear and goes in with a clonk (can do it on the move too but is most noticeable when stationary)?
IF the rear axle was out of line cos the ball joint was shot click this in away impact on the clutch (I cant see how but what do I know?).
Might change my signature for 'getting there'. Mr. Green
Post #407791 15th Mar 2015 5:23pm
Caterham
How strange....jumped indef this morning and before I pulled off the drive I knew things were good, nice smooth and light feel to clutch pedal. ? Great but why and how. Its been perfect all day?????
Not touched. It, no grease oil nothing and its never felt this good?
What the hell has happened to it?
Post #440538 26th Jul 2015 9:29pm
munch90
Say nothing , it only temps fate !
Post #440548 26th Jul 2015 9:54pm
Happyoldgit
You stopped being paranoid? Steve.
http://forums.lr4x4.com
Post #440637 27th Jul 2015 11:29am
And then you woke up?
Post #440710 27th Jul 2015 4:21pm
Roy5695
I'm not gonna lie or try and scare you but my double cab is in the dealers for this exact problem, The mechanic from landrover (not my dealer, actually from Land Rover) took it for a test drive and confirmed there's something wrong so he said the only thing to do was strip the gearbox down and take a look at what's going on inside...
I'll let you know how I get on when they've had a look.
Post #440755 27th Jul 2015 7:05pm
munch90
Everything sorted !
Hell must be freezing over
sorry caterham
Post #440759 27th Jul 2015 7:17pm
Caterham
Laughing Shocked
Done over two hundred miles today and all good with the exception of last 15 miles wherever there has been evidence of of things down down hill.
Is it possible the clutch plate wouldn't slide along shaft but get stuck and hence very heavy clutch pedal?
... so my thoughts are for whatever reason the clutch isn't moving back n forth properly hence not fully disengaging therefore poor gear changes, engine ecm isn't seeing a no torque situation and not doing the gear harmonisation etc? But why?
Post #440760 27th Jul 2015 7:27pm
munch90
When you press the clutch pedal the pressure plate moves away from clutch plate , so no it cant make it heavy
Post #440763 27th Jul 2015 7:30pm
Caterham
So other than the pedal itself what could cause the pedal to have so much resistance and then to move freely?...
Post #440778 27th Jul 2015 7:54pm
Roy5695
Did you skip leg day?! Ha Laughing
Post #440783 27th Jul 2015 8:08pm
munch90
ony things would be pedal or pressure plate , but never known one to be fine one min then heavy next , havent you just had the clutch done only a few weeks ago
or a knackered leg Rolling with laughter
Post #440786 27th Jul 2015 8:14pm
Caterham
Yes clutch replaced but 'this issue' remains?
It seems the issue relates to the actuation of the clutch?
Post #440820 27th Jul 2015 9:45pm
munch90
Maybe a slight change in pedal pressure between hot and cold , but wouldnt be much
take it cylinder was replaced at same time
Post #440824 27th Jul 2015 9:56pm
mk1collector
Post #440828 27th Jul 2015 10:23pm
Page 2 of 5 <12345>
