Home > Puma (Tdci) > Fuel cooler guard - needed or not?
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
I see from reading through the forum that some recommend the fitting of the fuel cooler guard even though the 2.2 does not have the cooler fitted.
Are the pipes really at risk when off-roading?
I see few different makes out guard out there all look the same
- Devon 4x4, electroplated steel
- Terrafirma, electroplated steel
- Wildbear, electroplated steel
- Nakatanga do both steel and aluminium
Will ally one be strong enough if protection is needed?
And obviously Entreq do a really expensive one Shocked
Post #440417 26th Jul 2015 10:45am
You'd be surprised what debris that could get up under there.
I've heard that if the fuel pipes are damaged they can be costly.
Not to mention you lose your fuel, your stranded and the fuel system and fuel filter would likely need priming,
Post #440419 26th Jul 2015 10:49am
Oh and D44 one on mine. Thumbs Up
Post #440420 26th Jul 2015 10:49am
Iktank
Ta Thumbs Up
I have contacted Brendan to see if he has the ally one and how much (will prob have to send him a reminder Laughing )
Had Zag treat all the underside so would rather have something that wont rust
Post #440433 26th Jul 2015 11:32am
I've had it in for about 3 years now, no rust signs so far.
I could have Dinitrolled it but decided to leave it alone.
Post #440434 26th Jul 2015 11:35am
Re: Fuel cooler guard - needed or not?
Iktank wrote:
I see from reading through the forum that some recommend the fitting of the fuel cooler guard even though the 2.2 does not have the cooler fitted.:
Maybe not true for all 2.2s, but mine has a cooler.
It's a really vulnerable position, and given the consequence of a knock then a good thing to fit a guard.
Saying that the likelihood of damage may be low, never seen a post from anyone who has damaged one?
Post #440437 26th Jul 2015 11:55am
Entreq on mine Thumbs Up
Post #440481 26th Jul 2015 3:32pm
TJ101
After one quite loose stone/rocky trip , decided to fit one the 09 110 5 year ago,, has been fitted to all Defender since, even though the last 2015 one has no cooler,, the pipes are at risk , and jave been know to be damaged offroad,, both inconvenient and costly for what they are
Devon 4x4 fitted,,not dear, works well, would buy the same again California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #440594 27th Jul 2015 8:19am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
I'm in the opposite camp, not needed. I don't have one fitted.
My 90 has spent 8 years doing some pretty serious off roading [As members on here can confirm] and I've never had an issue,
not even any signs of contact or scrapes on mine.
If it was 'that' vulnerable It's highly unlikely LR would of sited it there Neutral Guns and Landrovers .... anything else is irrelevant.
Post #440711 27th Jul 2015 4:24pm
TJ101
For the cost of what ?? £40 or thereabouts and after seeing at least one with ripped out fuel lines at ? IIRC over £250 plus the grief !! has to be a no brainer !!
But each to their own,, and when you hear the Moroccan beach stones rattling on the underside,, give some piece of mind !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #440724 27th Jul 2015 5:10pm
Someone on here had a stone hit the oil filter casing and all the oil fell out... That's why I got the entreq one
Post #440736 27th Jul 2015 5:41pm
Iktank
Thanks all
I think I shall get one, good point only £40 -£50 - run on stone tracks all day and other tracks lots worse
Better safe than sorry as they say
Thumbs Up
Post #440757 27th Jul 2015 7:10pm
jst
i had one a home in the garage ready to fit for a maroc trip, just hadnt got around to it.
two weeks after it had arrived i was driving a site with a fair bit of brash on the ground, small cut off went right up between chassis and pipe into cooler on my 2.4 kinked the pipe, i was lucky it didnt break it off, guess what - the guard went straigth on after that! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #440793 27th Jul 2015 8:31pm
That's the stuff I've had trouble with in another non-fuel cooler related incident.
Just sticks into anything in the way, surprising what it can da game or at least bend.
Post #440795 27th Jul 2015 8:37pm
