Home > Puma (Tdci) > Question - Ref: Air Intake Protection
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Around here after heavy rain there are some roads that flood due to poor drainage. Not infrequently on coming cars don't see or don't care about the water an speed through creating a substantial side wave which can be at the height of the engine air intake.
I know I can fit a Snorkel, and may have to, but most of the ones I have seen raise the vehicle height by some inches/cms which could prove a problem in some car parks.
Does anyone know of a protective plate that would stand proud of the air intake by a couple of inches thus protecting the air intake from direct entry of water, a bit like the air intake protector on external wall gas boilers to stop the wind blowing directly into the air /exhaust pipe?
Do you think this would keep out the worst of the water?
Can anyone suggest a snorkel that doesn't increase the vehicle height?
Any advice much appreciated.
Post #43948 30th Oct 2010 3:16pm
Lorryman100
I have the Safari snorkel fitted on my landy, it appears to be the same height as the roof. Thumbs Up
Post #43954 30th Oct 2010 4:47pm
K9F
With the Safari you can also rotate the head in severe storms to prevent moisture ingress whilst driving! Thumbs Up
Look in my gallery and there are direct comparison photos between Fekete's Mantec and my Safari snorkels with the vehicles side by side! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #43958 30th Oct 2010 5:00pm
Lorryman100
Found this advertisement for the Safari snorkel from oz. Dont think the local floods down your way WelshGas will compare though..........
although in a defender, your feet and ass might get slightly damp......... Laughing
Post #44024 31st Oct 2010 2:21pm
WelshGas
Too True Lorryman100.
Think I might try my hand at making something from Ally plate + tube as a spacer.
Paddocks make this:- [/url] http://tinyurl.com/35s2qt8
which could help - but not for the Puma
Post #44027 31st Oct 2010 2:38pm
ibexman
intake
fit a military air intake
Post #44028 31st Oct 2010 2:50pm
dgardel
Italy
now I'm looking for the military air intake
meanwhile
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #44035 31st Oct 2010 4:50pm
roel
Two thoughts:
1 I think you airintake can handle some water. I don't know the Puma intake in detail but with the Td5 the hose under the bonnet goes down first and then up to the airfilter. On the lowest point is a water outlet devise.
The design in total can handle a few liters off water before the water will go through the airfilter.
2. The military airintake looks to me that is for the air for the heater and not for the engine or iare the internals different too? Roel
2003 90 Td5 (2009-now)
Post #44050 31st Oct 2010 8:33pm
dgardel
Italy
Snow cover (see my previous post photos) is different from the Military (engine) Air Intake:
IID Pro MV License
Post #44062 31st Oct 2010 10:46pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
My air filter cover fell off about two or three weeks ago, and I've just carried on as though it's not been there at all and had no bother, even on rough muddy tracks and when jetwashing it off.
Obviously I'm not going to leave it like that for when the snow arrives, going to get a snorkel for it. Just trying to work out what the difference is between the new Safari Snorkel and the old one....
Not sure if I like the look of the base... Looks... odd.... Confused Or am I just being fussy??
Post #44064 31st Oct 2010 11:39pm
110SEB
No, I agree Warren, but I can't put my finger on it. It looks as though it slopes forward and isn't firmly attached.
Post #44066 1st Nov 2010 12:01am
ibexman
roel wrote:
Two thoughts:
It has a pre filter and supposedly gives you six inches more wading depth i have one on my td5 but dont know how to post pics here cheers chris
Post #44087 1st Nov 2010 1:10pm
