Home > Wheels & Tyres > 35" tyre pics
need4speed
35" tyre pics
Has anyone fitted 35" or 315/75/16 tyres to sawtooth alloys?
Post #439763 22nd Jul 2015 10:38pm
camelman
I thought the biggest tyre you could get on a sawtooth was a 285x75x16 (assuming it's a genuine 7x16 wheel)?
Without spaces or a further offset wheel you'd lose all steering lock.
I ran 305\70\16 s (effecitivley 33inch) on 16x8 mach 5 without issues.
Post #439766 22nd Jul 2015 10:45pm
need4speed
My mistake. I forgot that sawtooths we're only 7" wide Crying or Very sad
Post #439768 22nd Jul 2015 10:47pm
camelman
I believe some of the aftermarket guys do a 16x8 but you'd still need a wider offset unless you're into your 10 point turns Smile
Post #439771 22nd Jul 2015 10:49pm
need4speed
Maybe possible with 30mm spacers?
Post #439805 23rd Jul 2015 7:46am
K9F
I have just recently swapped over to exactly the same setup thanks to Camelman's historical advice. Thumbs Up
No issues whatsoever. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #439843 23rd Jul 2015 10:53am
need4speed
Really looking for the height of 35's.
Mind you the sawtooths might be out as the only 16" I can find are 7" wide. Only the 18" wheels are 8" wide...
Post #439846 23rd Jul 2015 11:08am
camelman
quite a few aftermarket alloys are 16x8, the twisteds I run are 16x8 with ET0 (i.e. 33mm further out per wheel).
Have you looked at 15inch wheel options? I believe there are more 35inch tyres at that size.
Are you after the 35's for the higher gearing or more ground clearance?
IT's definitely worth having a look at pics of some first as some of them actually 'look' quite narrow in relation to their height/
Post #439875 23rd Jul 2015 1:23pm
need4speed
I know there is lots of choice regarding tyres. I had originally considered 35's fitted onto modulars but recently I've been contemplating anthracite sawtooths. But they would need to be at least 8" wide for 35/12.5 tyres.
Post #439877 23rd Jul 2015 1:39pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
<snip>.
I'm sure I read somewhere (and cant find it now) that even 285's were not recommended for 7" rims. I know a lot of folks do, but wondered if there is any specific manufacturer advice on this..?
cheers
simon
Post #439879 23rd Jul 2015 1:58pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
According to ETRTO (European Tyre & Rim Technical Organisation - who's standards all tyre and rim manufacturers work to) they state the minimum rim width for a 285 section tyre is 7.5J. And max rim width is 9J. So no, 285's should not be fitted to std LR 16" 7J rims.
However that doesn't stop anyone, so queue replies of "i've got them fitted and they are fine" etc etc.
Post #439891 23rd Jul 2015 3:09pm
need4speed
And what about a 35/12.5" tyre?
Post #439893 23rd Jul 2015 3:27pm
L90Andy
Recommended Rim for that would be 10J
Post #439901 23rd Jul 2015 3:45pm
need4speed
Thanks for that. I had a feeling it was but I've had people elsewhere saying 8" was fine which I felt was too small..
Post #439907 23rd Jul 2015 4:00pm
