![]() | Home > Maintenance & Modifications > BLACK Bolt Sets |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
Hi,
powder is no option, it will chip whiest fitting. We are working on dying the bolts black in a special chemical process. The first samples are on its way. WANTED: SII or SIII in max 1.5k |
Barney12 Member Since: 09 Jun 2015 Location: South West Posts: 744 ![]() ![]() ![]() |
Excellent!
Hi Peter
One extra thought: If you have one of your stainless wheel carriers (as I do) then you'll need to produce an "add on" kit to cover those bolts too! |
IF it works, we will supply black bolts for the carrier anyway WANTED:
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 ![]() ![]() |
i have all my nuts covered in black plastic
Using plasticdip?
Not sure that would work on body bolts? |
Barney, think this German manufacturer will have what you need. It has been brought to my attention a while ago by a def2 member, but I don't think it ever was openly posted on here.
Eric http://www.mcgard.de/en/home/automotive/ra...ition.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Thanks, yes wheel nuts do seem available.
My interest is also in the body bolts/screws. Sounds like Peter might have a solution soon! |
Aha, missed what you were really talking about when you wrote "black bolt set". Black body screws, that is a totally different thing of course. In the meantime, I go back from stainless to standard on those.
![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 ![]() ![]() |
Watching with interest to see if the black dye process is successful. Cheers,
Kyle. |
Hi, any update on these? |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2660 ![]() ![]() |
'These Bolts are A2 Stainless steel and then PX3 Chemically Coated Black'
http://tmdtuning.com/shop/black-ssteel-security-bolt-set-90/ winner winner ? |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 602 ![]() ![]() ![]() |
I just gave mine a smooth coat of Hammerite, looks great and cost penny's
