![]() | Home > Technical > How to tell if you've a 36 or 48 Spline Steering Wheel |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2032 ![]() ![]() |
Found this helpful page on the net.
http://www.web-rover.co.uk/nav.php?p=articles/steeringwheels 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Unfortunately it's been proven again and again that although that link is correct in the majority of cases, the reality is that LR chopped and changed and the only sure way of checking is to remove the wheel and count splines
JimC Member Since: 22 Jan 2011 Location: NOVA Posts: 164 ![]() ![]() ![]() |
Press a chunk of clay into it and count by poking the splines.
Once you get to 38 stop if there are more cause it will be a 48 if you get to 38 and there's no more splines you have a 36
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
Count the ridges and valleys of the splines then divide by 2
mickygee Member Since: 22 Jun 2009 Location: sydney Posts: 44 ![]() ![]() ![]() |
count the ridges, then multiply by 4, then halve that number, and then halve again
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Buy two steering wheels one 36 & one 48......one will fit!
