Home > Technical > Rear 110 Prop alignment
jst
i have a 110 rear prop here, (11MY Utility if that helps!)
its out of alignment in that it has been separated and i am not sure exactly which way it was for re-alignment.
i have tried the two yokes in the same plane but balance is out.
anyone ay ideas on how they are factory assembled? there is a green mark on the female part of the prop but seemingly nothing to align it with.[/u] Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #438959 19th Jul 2015 8:50pm
walfy
I can take pics of mine tomorrow if thats any help?? 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #438995 19th Jul 2015 10:31pm
jst
Please, could do with seeing whole length so can see uj flange orientations, Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #439028 20th Jul 2015 7:32am
Fifth Horseman
Hope this helps - doesn't necessarily apply to front propshafts though.
Post #439029 20th Jul 2015 7:38am
walfy
James
Just home from work and as much as I want to help, I'm not lying under my 110 in the pouring rain Sad Sad .
I have a late start tomorrow so will try again then Thumbs Up 110 D250 SE HT
110 USW SOLD
Post #439136 20th Jul 2015 7:07pm
Lorryman100
Usually each half of the prop has an alignment mark on it which is marked on once the phase has been set and the prop is balanced. The only real way to re balance the prop is to mark a corresponding mark on the other half and move that shaft one spline and retry to see if it balanced. If not then move one spline each time until it balances. Very easy to do on a testing rig but needs to be fitted and tested, and if still not balanced removed from the defender for each spline test which for me would be a right pain.
JMTW Personally for the effort involved I would opt to replace it with an uprated prop from Gwyn Lewis.
http://www.gwynlewis4x4.co.uk/product/puma...rop-shaft/
Post #439172 20th Jul 2015 9:11pm
jst
cheers guys - 5th HM - thats what i tried first and its not right!
also tried lining up the green mark with the flange mark (like the other 110 prop i have here is assembled) that didnt work either.
looks like i will be working through rotations of alignment, something i was keen to avoid. especially as it need to be doing 65ish to find the vibration (or thats where it vibrated last time!) Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #439173 20th Jul 2015 9:17pm
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
Are you sure it's the prop causing the vibration? have you removed it and driven with the diff lock in?
I would just line it up like in the pic above and take it to somewhere and have them balance it, I cant see it costing very much to balance and stick a couple of weights on.. then you know your prop is perfect Thumbs Up
I would get both done if the price isn't much..
I just Goggled Prop shaft Balancing in Devon & Dorset and it brings up a few so you shouldn't have a problem, will be worth it for all the hassle of trying to manually align it and test in each configuration...
Hope you sort it soon, Vibrations are good for some things but not a Defender at 65mph
Browny... My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #439374 21st Jul 2015 4:47pm
jst
Browny i think you are spot in, looks like thats going to be the way fwd. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #439416 21st Jul 2015 8:39pm
jst
ok, i have a new prop here, it has a blue mark under the rubber cover which lines up with the rasied 'dimple' on the other male flange.
With the new prop flat on the bench at the non slider end:
the other end, complete with mark looks like this:
both ends of prop taken from vertical looking down.
meanwhile my other prop, the one with the issue i believe of being out of phase, looks like this
at the male end when the non slider end is placed square on the bench, you can see the marks are out and have been rotated one 'hole' clockwise. when it was aligned it created the wobble.
What i would like to know is are all 110 props supplied with the raised section lined up with the mark under the rubber? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #440191 24th Jul 2015 6:30pm
jst
blackwolf wrote:
Looks like they're about 70 degrees out of phase.
Edit -posted in the wrong thread because I could find the right one!
Blackwolf does the dimple line up with the mark on this one? any chance of a picture with the non slider end square to the bench, ie resting flat on the UJ cup 'holder' Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #440193 24th Jul 2015 6:33pm
Sorry, it isn't actually my photo, I stumbled across it on Ebay and thought it might be useful.
I then couldn't even find the right thread, so all in all I wasn't at my best! Big Cry
Post #440194 24th Jul 2015 6:47pm
If a propshaft is fitted in an application where the two flanges (diff and gearbox) are not coplanar, the yokes of the shaft are intentionally un-aligned to prevent vibration. Classic LRs are coplanar so the yokes will align. The Puma-engined ones are no, since the engine and transmission are raised at the front. As a result, Tdci propshafts will have the yokes misaligned intentionally, and will differ from TD5 and earlier even if the same length.
I'm afraid it is too wet for me to crawl under the truck to look for alignment marks at the moment.
Post #440197 24th Jul 2015 6:56pm
Rickydodah
If it's any help; I've had mine off today to replace UJs and if the axis of the fixed end is at 0 degrees then the sliding end was around 20 degrees from vertical. I couldn't see how the sliding joint comes apart but the splines are fairly large so would say around one spline out of phase. Confused I started with nothing and still have most of it left!
Post #440199 24th Jul 2015 6:59pm
jst
cheers, 20deg which way if you looked end on to the male part (counterclock wise is my guess) Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #440210 24th Jul 2015 7:38pm
