Home > Maintenance & Modifications > How do I reset the oil service light on a 15MY Defender |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 |
Take it back to a dealer and ask them to turn it off and ask why its done it?
16th Jul 2015 4:44pm |
adamatdraycott Member Since: 11 Nov 2013 Location: Midlands Posts: 299 |
The service interval is set at the factory, not the dealers as far as I am aware.
My build date was 27th Jan but I picked it up 1st March, so my indicator was lit for a month or so before the service at the end of Feb You haven't done over 12k mileage have you? |
17th Jul 2015 7:44pm |
V12vanquish Member Since: 28 Sep 2014 Location: Northern Ireland Posts: 52 |
No approx 700 miles only, it's due the service next month.
I just wanted to reset the warning until next month. I really think it's a scandalous waste of the earths resources to dump the oil after so few miles, it isn't even black yet, there is no way that oil is junk. One dealer I phoned today wants £326 for the first service. |
17th Jul 2015 9:01pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16891 |
Don't forget that the main reason for the OSL is to guard against engine damage resulting from oil dilution caused by the DPF regeneration cycle. Even on a low mileage vehicle it is possible that, dependent on usage profile, it may need the oil changed. 600 miles does sound ridiculously low though.
17th Jul 2015 9:11pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Old oil os recycled alot these days, that's if its disposed of through correct means. Land rover will certainly do this .
Its mental the price LR charge for an oil change their is absolutely no value for money. It is simply the most expensive service stamp you can buy. Just ignore it and wait for the service bud. Pedal tricks are awkward to use I've never been successful with them |
17th Jul 2015 10:30pm |
A lot of old oil goes to tarmac companys and burnt to heat the tarmac
used to be able to sell it , it was only few pence a litre but if you had few hunderd gallons taken it was worth it , but now the storage regs etc have tightened up and you have to get rid of it more regularly the recycling companys know this and stopped paying for it |
17th Jul 2015 10:43pm |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 |
Hi,
I will be interested to know why it is on. On a def 2012 as mine, it is easy to do it. Unfortunally , even if I have do it 2 or 3 times , I do not remembrer exacly how ! i am on hollydays and I have notted at m'y office ! I am sure somebody will tell it go you. Otherwise I will be back in 10 days Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 Last edited by Phil VM2.5 on 27th Jul 2015 7:25am. Edited 1 time in total |
18th Jul 2015 4:03am |
PumaPhil Member Since: 26 Oct 2014 Location: Bridgend Posts: 201 |
Does my my16 have a service light, and if so where is it? Planning on my own servicing after warranty is up in 3 years
26th Jul 2015 7:07pm |
It comes up at the bottom of the mileage display in the speedometer on start up, it gos out after a few seconds.
26th Jul 2015 8:56pm |
Ok, thanks
26th Jul 2015 9:09pm |
1. Ignition ON pressed both “brake” and “accelerator pedal” full down for 15 seconds
2. Oil light started to flash. 3. Turned the ignition OFF and left it for around 2 mins. 4. Oil service indicator cleared. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
27th Jul 2015 5:48am |
Hi,
I am back at my office but dgardel have answer ! Thanks Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
27th Jul 2015 7:27am |
Several threads on this already.......
TIMING IS CRUCIAL...GET IT WRONG IT WILL NOT WORK.... http://www.defender2.net/forum/topic34134....il+service If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
27th Jul 2015 7:37am |
Wessex517 Member Since: 28 Feb 2019 Location: Wellington, Somerset Posts: 12 |
1. Turn the ignition on and immediately press both brake and accelerator pedals simultaneously full down for 15 seconds. 2. When the oil light (picture of an oil can) starts to flash turn off the ignition. 3. Release the brake and accelerator pedals simultaneously. 4. Wait for two full minutes. 4. Turn on the ignition and see if the OIL SERVICE message has gone. If not repeat the procedure exactly. It DOES work but not always first time. Mine cleared on the third attempt. |
28th Feb 2019 4:38pm |
