Home > Tdi > Connector underneath centre seat |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 405 |
Hi all,
I've been tidying up my recently purchased 300 Tdi (1998 hardtop) and come across a round connector underneath the centre seat. It's white and has a black cover over it. Any idea what this is for? Thanks. Andy |
11th Jul 2015 10:14pm |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
EGR controller I believe. www.td5.org
11th Jul 2015 10:16pm |
Thanks but I think the EGR controller is the black rectangular box with a black rectangular connector. This comes through the centre seat box panel with the EGR ECU cable but is separate.
11th Jul 2015 10:18pm |
Yes, it's a creamy coloured round connector.
No central locking nor a security system. Bit of a mystery - I'll put a voltmeter on in tomorrow and see what we have. |
11th Jul 2015 11:23pm |
has it got abs ?
the early rover cars had a round socket about 40-50mm long and 20mm across with a back soft cap , the cap had a bit sticking out the end used as a handle to pull the cap off and a retaining ring to keep the cap attached to stop you losing it they were the early type of diagnostic/programming socket used before the oblong obd socket became standard on the early rover cars the round sockets were one function only so you could have 1 for engine , 1 for security , 1 for abs depending on what was fitted |
12th Jul 2015 8:38am |
Thanks. That sounds like it. No ABS, or any other comforts come to mention it, so probably an early diagnostic socket as you suggest.
Thanks again for your help. Andy |
12th Jul 2015 1:39pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 488 |
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
17th Jul 2015 10:23am |
That's the kiddy.
Thanks Paul, A |
17th Jul 2015 4:05pm |
