![]() | Home > Puma (Tdci) > Service action - Q054: Brake Pipe Contact with heat shield |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
For your information a new service action was issued last week.
I think that some of you had this problem Regards Model: Defender Right-Hand Drive with ABS Model Year: 2007 to 2008 VIN Range: LD 732615 – LD 752724 A limited number of 2007/8MY Defender vehicles may have been manufactured away from process and in some cases; the rear brake pipe may have been incorrectly routed/fitted resulting in reduced clearance/contact with the heat shield. If the rear brake pipe is in contact with the heat shield, this may result in the brake pipe wearing through. Action to be taken You are requested to contact the owners of the affected vehicles and request that the vehicle is made available at the earliest opportunity so it can be inspected and where necessary the brake pipe be re-routed or replaced. A sample customer letter for you to use is attached as Appendix 1. The workshop procedure is attached as Appendix 2. Please ensure all unsold vehicles are repaired prior to handover to the customer. Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
has anyone actually been contacted to bring in their vehicles?
Mine has worn quite a groove in the heat shield already and I got mine in Feb 2008. Will give the dealer another week and then call them myself. Not nice waiting for an accident to hapen Puma 110 - gone Series III 1973 - going strong |
