![]() | Home > Td5 > clutch cylinders replacement |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
All Defender clutch master cylinders are the same, yep
Also the "T" piece is two banjo type fittings, which do look like a "T" when together
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 292 ![]() ![]() |
o.k. cool!
Thx A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
Well, cylinders done. As usual it wasn't the bits that you'd think would take the longest that did.
Slave cylinder not a problem ..... until it came to trying to connect up the wee metal pipe from the slave cylinder to the flexible hose. slave cylinder + hose mounting bracket on top bolt no problem fitting that pipe that goes from cylinder to hose .... nope not enough room. cylinder minus hose mounting bracket + pipe from cylinder to hose - not a problem. Took ages to get everything connected! Master cylinder - yup move the coolant header tank a wee bit and everything came out and went back in again no problem. Trying to slide the plastic bits at the back over the metal mounting bracket took ... shall we say .... a while. Just as I was about to say " ![]() After that it was just a case of bleeding the system. Still a wee bit of air in there but it'll sort itself out. quite pleased really A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Nothing like getting a job done by yourself
![]() Well Done ![]() Self confessed mileage hunter ![]() |
Next thing on the list is to replace manifolds and Zenith carb on my Series 3 with an ACR Engineering SU carb setup + both manifolds.
![]() A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
