![]() | Home > Td5 > Emissions/Smoking |
| ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637
Have you tried diesel additive such as redex?
It sounds like the injectors are carboned up. Worth having a look for diesel additive, I think there is more powerful stuff than redex available, but might be trade only. My TD5 has 172k and sailed through its MOT, doesn't smoke and doesn't use oil. Cheers |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Has it been serviced recently? Ray
| Northernremedy Member Since: 18 Aug 2014 Location: Yorkshire Posts: 122
Hey!
Yes literally serviced about three weeks ago, new MAF fitted. Re the injector cleaning, wondered about that but currently running few tanks of v-power through it, been advised probably best not to put both in at once as the v-power has additives in |
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435
Try cleaning the MAP sensor, the one on the inlet manifold, easy to do, remove it and give it a good clean with carb cleaner or similar, make sure your air filter is clean too. If that fails have a look at the turbo and inter cooler hoses, one might have split or collapsed inside.
Thanks for that. Yes I'll whip out the map and see what it looks like. Maybe some silicon hoses be no bad idea
| Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482
Try this apparently what the dealers use.
http://www.forteuk.co.uk/product-detail/47...or-Cleaner you can get it on ebay in a double pack turbo cleaner and injector cleaner. my guy who maintains mine fills up the fuel filter with it and runs it neat through it for quick blast but it works well just in a tank of fuel. Stopped mine smoking a lot. |
| Hunter75 Member Since: 29 Aug 2013 Location: Oxford Posts: 2
Back to get the re map tweaked Mate and it will not be long till the egr will have to be present and working to pass MOT
There going to plug in all our cars soon Mines still in my shed... Get some Fuel System cleaner in there it will not harm it I've ran Millers and v power at the same time on a 200 mile run.. Is the car eating oil mite be injector seals ? |
| Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532
TD5 EGR is a mechanical valve. How is a diagnostic computer going to tell you it's working
To the OP, check the boost pipe work for splits/leaks, as well as the intercooler. And oil ingress into the injector loom Failing that, you may need it plugged in to check for any faults, and make sure all sensors are reading OK |
