Home > Maintenance & Modifications > Cubby box raising and putting a SubWoofer underneath
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Has anybody tried this?
There are several compact (underseat) subwoofers at about 8cm tall which could go under/in a suitably manufactured cubby box raiser.
Post #43671 27th Oct 2010 4:14pm
AndrewS
Why mess about with the cubby box, stick the under seat sub under the drivers seat in the seat box Thumbs Up
This one fits
http://www.caraudiocentre.co.uk/product_m-...-25817.htm
and this one
http://www.caraudiocentre.co.uk/product_m-...-22595.htm 130's have feeling's as well you know Smile
Post #43673 27th Oct 2010 4:53pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
if you have a 110 then i would put it under the rear seats.
i have a 90 and installed the Alpine which has a bracket that you can screw to the floor behind the cubby box so it is self supported and out of the way.
if you search you will see pics on here somerwhere for both installations
cheers BM52
Post #43679 27th Oct 2010 5:56pm
AndrewS
Wont it get Censored and damaged if you fold the 2nd row seats forwards and place a load into the vehicle Question 130's have feeling's as well you know Smile
Post #43689 27th Oct 2010 7:40pm
bm52
true, but i hardly ever drop the seats in my FL.......take your point if you need the load bed - not a good idea. Rolling Eyes Rolling Eyes Rolling Eyes BM52
Post #43692 27th Oct 2010 7:52pm
iruffell
I don't want to put it under the rear seats, as Andrew says it will get damaged when seats are folded, also not keen on having it on show by bolting to the rear of the cubby box.
Andrew, are you suggesting bolting it to the underside of the slide out cover under the seat? Will the sound get through ok?
My thought was to make up a steal or ali box, with the ends missing and mount it inside underneath the cubby box so you get the added bonus of raising the cubby box a bit.
Post #43716 27th Oct 2010 9:55pm
AndrewS
Bolt it into the bottom of the box under the seat, sound gets through OK, hey try it there first before you go altering the cubby box. Unless you want to fit it under the cubby box Thumbs Up 130's have feeling's as well you know Smile
Post #43719 27th Oct 2010 10:09pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
Blaupunkt make a good one.... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #43724 27th Oct 2010 10:42pm
discocuzzy
cheers
As above, mounted the amp and a low profile sub under the seats:
 You cannot teach stupid people to do clever things
Post #43742 28th Oct 2010 9:00am
Naks
Doesn't that house the ECU?
On another note, this is my current speaker location (JBL 6x9"):
However, when loaded with overlanding kit, you can't hear them. Where else can I place them? I was thinking in the rear roof corners, but does that work?
Post #43743 28th Oct 2010 9:07am
AndrewS
No thats under the bonnet located at the top of the fire wall/bulk head in the centre of the vehicle. Thumbs Up 130's have feeling's as well you know Smile
Post #43748 28th Oct 2010 9:41am
Naks
Awesome. Now we can look forward to the ECU melting due to engine heat Rolling with laughter
Post #43749 28th Oct 2010 9:42am
MK
That is an interesting setup. As you was thinking to put them on top rear, but a selfmade box it is needed for such location. I guess wood and fiber glass could do the job.
Just and idea: How about making those speaker boxes a bit taller? Abviously the small rear windows will be blocked.
I also tend to load with stuff and cr&p the whole rear. Puma 110" SW
Post #43750 28th Oct 2010 9:45am
Naks
Wood is probably better. Car audio shops in RSA have them lying around and will sel lthem cheap.
Also, I remove the entire rear trim to gain more space for packing - it also removes a lot of rattles Smile
Post #43751 28th Oct 2010 9:46am
MK
Any way, with your design do you get decent bass tones? I ask beacuse I wouldn´t bother to use LR Censored rear plastic panels to screw any speaker. Puma 110" SW
Post #43753 28th Oct 2010 9:52am
