Home > Technical > Tow bar too high
vogue se
Belgium 2011 Defender 90 Puma 2.4 Exclusive HT Nara Bronze
Tow bar too high
For those with problems of a tow ball which is too high for a NAS bumper. See solution below.
I use now a tow ball from Westfalia 3.5Mt. Now it's perfect and 100% legal when you use minimal 10.9 or higher bolts and nuts.
Post #436577 8th Jul 2015 6:59pm
munch90
how much does it lower the height of the ball over a standard ball , doesnt look much , moves ball out which is handy
Post #436581 8th Jul 2015 7:47pm
TJ101
As munch really ?? How much did it drop the tow hitch hight by ? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #436595 8th Jul 2015 9:03pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
If remember correctly 30mm.
Post #436639 9th Jul 2015 7:25am
Wheel
Hi Vogue SE
Can I ask what NAS step you have fitted, is it LR OEM or after market as it looks not to be secured at the end of the rear X member ?
Thanks,
Mark
Post #439204 20th Jul 2015 10:49pm
It looks like the short version fitted to the X techs by JLR:
Post #439281 21st Jul 2015 10:32am
vogue se
Sorry for the late answer.
The NAS is a OEM LR type delivered as standard on my 2011 Defender. Same type as the on efrom Supacat. Nice motor btw.
The difference is 50 mm with a straight type. see images below. Sizes are metric in mm.
The new hook is a Westfalia 3 29062600001. Cost in Belgium around 60€. Westfalia does have more options to go even lower if needed.
Look for more options at page 357 https://www.westfalia-automotive.com/filea...e_2013.pdf
Before
Now
[/url]
Post #443438 5th Aug 2015 5:40pm
My trailer is slightly nose heigh but not enough to worry and I only tow light.
Still looks not quite right though, I was thinking of rather than messing with trying to get a lower or higher coupling putting larger wheels and tyres on the trailer instead.
Mine has flotation tyres on it so I'm assuming they are a bit smaller than normal anyway.
I really ordered road wheels but got flotation instead once arrive but went with it. But that's Off Topic
Post #443448 5th Aug 2015 6:03pm
vogue se
Post #443456 5th Aug 2015 6:13pm
vogue se
Thanks for your comment Steve.
Consider this. My Def has standard suspension. But with a twin axle trailer only the rear were really touching the road.
Normally you should have 48 cm from ground to the center of the ball(hook). But trailer manufacturers advise between 38 and 42 cm loaded.
This makes it for everybody a little bit different for me this was the best choice.
The purpose of my message is that you can avoid situations with home welded lowering plates in combination with 8.8 bolted hooks and being involved in an accident with children. The solutions I'm proposing is serving me well and is fully road legal. I'm having a good sleep and nothing to worry when things should go wrong. Wink
And above all it's a very cheap solution.
Post #443458 5th Aug 2015 6:17pm
dioliahary
I had a similar problem albeit with a standard Dixon bate set up, managed to drop the tow ball by welding drop plates but it still sits a bit high IMO
Post #444633 9th Aug 2015 8:47pm
