![]() | Home > Tdi > Hot and Cold Tdi |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
Shaggy you should invest in an engine watchdog! The piece of mind is great! I've seen my engine getting a bit hot without any indication from the dash gauge! I never look at dash now as I can accurately monitor temps real time! My 109 thread
my youtube channel |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Do you have a pic of your set up?
As I say I'm trying to keep it all as standard as I can but if I can stick this somewhere discrete linked to a bulb on the dash may help a bit? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Think you have seen it before. Sensor is attached to back of head using existing bolt ![]() ![]() Click image to enlarge My 109 thread my youtube channel |
Can that unit measure block temperature? My 109 thread my youtube channel |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 368 ![]() ![]() ![]() |
You can check it out on their website. I'm currently monitoring the following: volts, coolant level, coolant temperature, gearbox oil temperature, egt & engine oil pressure.
Thanks G-mack - yes of course I have seen it I must have been having a derp moment.
Jfh, thank you for that, I quite like it but think it may be a bit too technical at this stage but will definitely keep in in mind ![]() I have a feeling it might be the sender so I'm going to change that first as its the only thing I haven't done so hopefully that will fix it ![]() Self confessed mileage hunter ![]() |
Browny90 Member Since: 20 Jul 2015 Location: Derbyshire Posts: 183 ![]() ![]() ![]() |
Hi All, new to the site so thought I'd stick my nose in..
Out of interest, is your truck a genuine 200, or been converted from a disco? If so, there are differences between the temp sensors from the disco to defender, often overlooked during the conversion, if it still had the disco sensor fitted it could be giving odd readings on the gauge.. Just a thought.. Browny ![]() |
Hi Browny,
Welcome to the site ![]() Mine is a genuine factory 200Tdi so should have the correct sender in it - that said it was owned by the environment agency for many many years so thats not to say they didn't swap sensor at some point. It hasn't been doing it as much recently now the weather has cooled off a bit but its still on my to do list. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
