![]() | Home > Camping, Caravanning and Holidays > Alko stabiliser hitch |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 ![]() ![]() ![]() |
A question for the tin tenters among you.
I have an alko stabiliser hitch on my caravan. My defender has a standard tow set up with a Dixon bate ball and pin hitch, bolted through the lowest holes. The problem I have hitching up, is the lever for the stabiliser fouls on the spare tyre (cross contact). This prevents my from hitching up as the pads are too far out. I have to remove the spare wheel and jobs a good'un. I'm wanting to put a mud terrain on the spare, does anyone have this? What are my other options? I suppose a swing away usually sits higher? Thanks Simon |
I used to hitch up my caravan with the back door open and when hitched up and the lever handle down then shut the door. Some people take off the handle and put a shorter one on or just fit it to hitch up when needed.
Thank you both for the replies. I will try hitching up with the door open first. Why i never thought to try that, im not really sure. If that does not work for whatever reason I will have a look for an adaptor as you suggest amondeggs.
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
A shock link shifts the tow ball about 2" outwards which helps
A swingaway wheel carrier shifts the spare wheel to the offside which helps. We have removed the red handle. It is slightly awkward to fasten the handle down without the extra leverage but a size 9 sorts that problem out. Brendan |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 ![]() ![]() ![]() |
Thanks again all. Such an informative forum.
I use a Dixon Bate adjustable hitch with an Akho towball bolted on with a 1/2" drop plate used as a packing piece.
