![]() | Home > Maintenance & Modifications > oil/water leak? |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Could be from the aircon and they don't have a mount on that crossmember Ray
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
If its clear water , not green,red,blue then it from the aircon drain that is above the gearbox and normally drips for a min or so after you stop and switch off
Try to collect some to check colour and check coolant when cold no mounting on the crossmember gearbox |
| nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Thanks m1 munch....... hope its normal as the ac was only on for a couple of minutes and it did look like a decent amount of water i dread to think of the condensate would be like on a long journey!its a bloody daft place to have a drain as the water is covering some of the electrical wires .........it appears to only leak when the AC is running.....i was wondering if the black thick oil was from manufacture spilt or somethingas its on he top of the gearbox?anyway thanks for the info!
| All times are GMT |
