![]() | Home > Puma (Tdci) > Airconditon fuse / Wiring diagram |
Td5 Member Since: 29 Jun 2015 Location: Finland Posts: 53 ![]() ![]() ![]() |
Hello,
I just recently bought a 2007 90 Defender Puma and the A/C don't work. Did some preliminary checking and the A/C fuse was blown, replaced it and it blew immediately when A/C switched on. Disconnected the condenser fan and the fuse don't blow. Hooked power to the fan and it run OK. Switching on the A/C when condenser fan disconnected, the fuse don't blow, but compressor don't start. There is "enough" refrigerant in the system, checked pressure. I have the factory service manual in PDF, but from where could I get the wiring diagrams? There is suspicious jumper wires in the fuse box, so probably I have some electrical work to do. Sorry about my English, I'm not native English. TIA, Juha |
RHD but wires will be the same...
![]() Diagrams....follow link. Good luck! ![]() https://onedrive.live.com/view.aspx?cid=4B...&wdo=1 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks, K9F.
Got the wiring diagrams, but wondering where the relays are? There is a separate relay for the A/C clutch and one for the condenser fan. They probably are under the seats, but someone installed Recaro seats that do not have the cushion removable, I have to take some photos to show what I got. These I have somehow convert so that the whole seat can be removed easily if/when needed. Could someone tell the location of these relays, please. |
Either under the passenger seat or under the steering wheel on right hand drive vehicles.
![]() Treat every day as if it is your last....one day you will be right!! |
