Home > Puma (Tdci) > 2.2 mpg
Page 3 of 4 <1234>
grafty99
I'd definitely be up for removing the dpf, cat and egr but the dpf is so close to the bulkhead that it would be a nightmare to remove and then replace for every mot. Also I'd have to wait 3 years to do it Big Cry 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #434772 30th Jun 2015 9:44am
Cafe Latte
Australia
No MOT here in Queensland Aus Very Happy
Chris
Post #434781 30th Jun 2015 10:10am
Stickleback
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Aintree Green
Having now worked it out, I get on average 25.5 to the gallon.
Interestingly towing a trailer (about 1,000kg) seems to make no difference to fuel consumption. Probably drive more smoothly and less quick towing so maybe I could improve MPG if I adopted a towing style of driving even when solo.
But where's the fun in that Thumbs Up
Ps 2014 2.2 with 9,000 on the clock
Post #434825 30th Jun 2015 1:49pm
def_fid
United Kingdom 2012 Defender 110 Puma 2.2 USW Stornoway Grey
2.2tdci 2012; BAS Remap 20 inch Wheels, Coopers
My Old 300 tdi would only get above 30 mpg if I kept the speed down to 55mph, the speedo read 62-3mph. More than 10% fast. The odometer was also likely to be similarly more than 10% over-reading. If I drove at 75-80 mph, it dropped to 22mpg. My current 2.2 has a totally accurate speedo. I can cruise at 80-85 and I get 25mpg. I haven't tried trundling along at 55, too much fun Rolling with laughter
Post #434870 30th Jun 2015 6:35pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
2.2 2012
Hi,
driving as an old man, at 2000 t/min approx 90 - 95 km/h , sometimes a trailler ...
- first year average 29 mpg - 9.71 L/100km) (26000km)
- year 2 : average 31.8 mpg - 8.88 L/100km (25000km)
- year 3 : average 31.8 mpg - 8.88 L/100km (25000km)
last hollydays in Auvergne june 2015 : 33.7
hollydays again Auvergne : july 2015 : 35.1
try 35 mpg, (8 L/100 km ) but not easy ...
Regards
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #434998 1st Jul 2015 8:54am
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
My 2.4 was shocking from new,I couldn't get under 14ltres per 100,now with over 100,000k's on the clock it gets 10 per 100.Give it time to settle in and don't baby it,drive the sucker. Pat
Post #435040 1st Jul 2015 11:38am
The Gairloch 1
Scotland 2014 Defender 110 Puma 2.2 CSW Aintree Green
Re supercat
"Always seem to get better figures when touring in the summer in higher temps, even after discounting the type of driving done"
There is some science behind better fuel economy in the summer. As a lorry driver 30 years ago I found I got better mpg by to filling up in the morning as cold fuel from the underground tank expanded with heat. Before anyone shouts this down I have proved it to be true many times and have witnessed other drivers filling their tanks to the brim in the evening, parking up for the night, and seeing a puddle of diesel under the lorry as the fuel expands. I am surprised no one has designed a fuel heater to make use of this phenomenon.
Post #435488 3rd Jul 2015 9:57am
WhiskyJackR
I have a late 2013 2.2
It consistently averages around 24 mpg
Post #436200 6th Jul 2015 10:01pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Here are my results from new;
As you can see there is a noticeable change on the graph. My commute is now 11miles instead of 4....
Post #436530 8th Jul 2015 3:06pm
Pickles
Re: 2.2tdci 2012; BAS Remap 20 inch Wheels, Coopers
"Cruise at 80-85 mph"?
Pickles.
Post #436628 8th Jul 2015 11:24pm
Neil1967
Netherlands 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Very early days yet, but my new 110 XS does 25-26 MPG. The previous 2001 110 TD5 did 26-28MPG, and the 1983 110 V8 before that did 13 MPG on LPG, so price wise all much of a muchness.
Neil
Post #436722 9th Jul 2015 4:19pm
def_fid
Pickles.
Only in France😉
Post #438763 18th Jul 2015 4:22pm
munch90
Re: Re supercat
I would say it would take a lot longer then between morning and evening to warm fuel up in a underground tank
yes agree with fuel expanding over night from a underground tank as the small amount in vehicle tank will warm up without the insulation of the ground around it
technically you should get less power from warm fuel , so mpg should suffer with warm fuel , one reason why dragsters will run ice packed fuel coolers to get denser fuel to give more power per certain amount of fuel
but I would say the diffirence would be so small you would be hard pushed to notice it on road use
Post #438765 18th Jul 2015 4:38pm
lohr500
Neil
Ah yes but I bet the sound from the V8 was the best Very Happy
We had a Disco 1 V8 with an LPG conversion and it made me smile every time I drove it.
That was when I wasn't fixing the endless stream of electrical problems that plagued it on a regular basis.
Post #438771 18th Jul 2015 5:42pm
SergeantJav
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
First run down through France and low 20s but then up around 80 on a motorway won't help Rolling Eyes
Post #440542 26th Jul 2015 9:36pm
Page 3 of 4 <1234>
