Home > Australia & New Zealand > Remap to turn off EGR Puma
Landie
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Does anyone know if there is anyone in WA that does a EGR turn off remap. Had a guts full of mine.
Post #434163 28th Jun 2015 4:15am
Tim_NZ
Australia
Not in WA, but Bell Auto Services, (site sponsor), can do what you want remotely.
Post #434171 28th Jun 2015 7:27am
K9F
As stated it can be done remotely, by more than one tuning provider, many people have used this convenient method myself included. Thumbs Up
http://www.defender2.net/forum/topic32903.html?highlight=remotely If you go through life with your head in the sand....all people will see is an ar5e!!
Post #434204 28th Jun 2015 10:15am
Or Alive, both Bell and Alive do it remotely. It's not difficult to do yourself.
Thumbs Up
Post #434215 28th Jun 2015 10:59am
bell-auto-services
We have a couple of remote options that can do this. The first and more commons is along with a remap done at the same time using our new BAS2 RRC. The second is with the same unit purchased as a hardware only option with the added add on for EGR delete only.
https://secure.bellautoservices.co.uk/stor...p-control/
Regards Pete
Post #434333 28th Jun 2015 7:21pm
Landie
As I'm not very computer savvy how easy is the remote option or would I be better off with the hardware option which i presume is a plug and play thing.
Post #444382 9th Aug 2015 1:17am
Tim_NZ
Australia
BAS Remote option is really easy, and if you get stuck I can give you a hand, (I'm in Perth).
Cheers,
Tim
Post #444386 9th Aug 2015 5:49am
HardCharger
Hi All!
I'm thinking of going this route but was told that before I could do any re-maps I had to update ECU to the latest version firmware. Is this true?
I'm in the process of upgrading but always encounter and EGR error on the Autologic so it doesn't fully update. Now I don't get a MIL light so it's not a failure but I'm guessing it just got mucked up when the turbo sprung a leak I used to have the chucka - chucka - chucka sound thingy but not anymore. Turbo is all sorted now but I think the first option in this case is to try and clean the EGR? Is there a post somewhere where they show the actual process of doing this? I tried to search but came up nil on any step by step guides, what is usually found is the mention that it was cleaned.
Now if I don't need to update the ECU to the latest firmware to get the benefits of a re-map, I don't need to touch the EGR anymore, correct?
Post #444724 10th Aug 2015 3:49am
K9F
Depends if it is stuck open slightly it will not close fully surely? You need the EGR to be serviceable to ensure it closes fully to get the benefit. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #444730 10th Aug 2015 6:51am
Landie
I replaced my EGR and 14 months later the new one got noisy. As I had the old one still I pulled it apart just prised off the metal cover clips. Degreased and cleaned out all the soot. Lubricated all moving parts with Lithium high temp grease and reassembled. Then had mechanic replace it. Still works good but I still want to turn it off for good.
Post #444780 10th Aug 2015 10:06am
HardCharger
Hi K9F, how do you know if it's fully closed or not?
Hi Landie, useful info, I'll do what you did and see what happens. It's quite a pain to get to though as I was looking at what either has to be removed or what you have to work around just to even get to it. Would it help to get to it from the bottom of the truck rather than from above?
Post #445334 12th Aug 2015 1:56am
Landie
Sorry mate I cant help you in how to remove or replace. Im a sparky so I left it to my mechanic.
Post #445335 12th Aug 2015 2:29am
HardCharger
No worries, Landie. The information you gave was plenty good.
Thanks again!
Post #445342 12th Aug 2015 5:39am
Landie
Just a thought. Once you get the EGR off you can test operation touching 12v on the coresponding plug pins. This should make the plunger (driven by a little motor and gearbox) go up and down. Mine was hell noisy at first but after a clean and grease it was quiet as. Hope this helps
Post #445391 12th Aug 2015 10:16am
HardCharger
Coolness! Thanks Landie! This will help a great deal. Thumbs Up
Post #445393 12th Aug 2015 10:18am
