- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
gilarion
A lot depends on the ambient temperature such as if it is freezing or a hot sunny day. However the average temperature of the water entering the radiator of a fully warmed up 200TDi engine is approximately in the region of 86°-88° C normal running. This temperature will rise to 91°C when pulling up a long steep incline. If towing on a long steep incline the temperature will often rise to 98° C and my advice if this happens is go easy and when you reach the top of the incline pull over and let the engine cool down a little.
A rough guide is that usually on your thermostat will be a temperature mark saying what temp it will open at. The standard fitment 200TDi thermostat will open at roughly 88 deg C.
I believe that Land Rover also fitted a thermostat that opened at 74°C for Hot Climates For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
26th Jun 2015 3:15pm |
cornish rattler
I will take the advice and try a 2.5td temp switch first Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
26th Jun 2015 8:00pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
