![]() | Home > Technical > hi lo revs switch |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
guys - no doubting what's been said here but I do have to wonder......
if the hi/lo is either in or out of gear how do you think miserableoldgit couldn't get a smooth gear change and it turned out to be the hi not fully engaged? miserableoldgits symptoms are pretty much exactly as mine in terms of not getting a smooth gear change? |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Stop wondering and start taking the advice that's been offered! Go and test the detent mechanism as suggested by Blackwolf instead of constantly 'theorising' or take it to someone who knows exactly what they're doing instead of just tinkering! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I was just trying to understand how this all works. Will be taking BW's advice when I get home and methodically working through what's been said and recording details accordingly..... me tinker - never |
Good, sound advice.
In mitigation if you remove the tunnel tray which does take a bit of time getting access to without cutting carpets, the linkages are easy to disconnect and you can drive it without refitting. Should you break down and if you've skinny long legs you can Fred Flintstone it home by sticking your pins through the apertures and walking it home. At the very least cleaning the linkages down as they may be encrusted with underseal or any other crud may be a good move just as an elimination process. Treat every day as if it is your last....one day you will be right!! |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18034
Oh Lordy! Now you've initiated the "Caterham's Carpet Catastrophe" thread (or the "Caterham's Mat Meltdown" thread if he doesn't have carpets).
"One of the plastic plugs which holds the carpet down in the passenger footwell is crooked in its hole. Could this be the reason for the Greek National Debt and also why my MIL light doesn't work any more?" Sorry Wayne, only pulling your leg! Last edited by blackwolf on 24th Jun 2015 3:07pm. Edited 1 time in total |
thank you both very much and will go away and try / do as suggested above.......but (as I start running for cover as if I'd just thrown a grenade).
Miserableoldgit was of the opinion.......tell you what I'll PM him to keep the piece |
I have re-read M.o.G's comments which you quoted above.
A worn high/low selector sleeve or hub could conceivably cause this, if it was worn so that when not fully engaged there was excessive slop between the rear output shaft and the high range gear. If this was the case, then there are two simultaneous problems occurring: (1) the wear noted above, and (2) a failure to engage the high range selector sleeve fully, so the selector shaft detent isn't holding the selector. Wear sufficient to cause (1) could make (2) more likely, though, so it is possible. You really don't want to ask how to check for wear in these areas, though! |
go on then.......you've tempted me......how do you check for flange wear........(and could following be related- flat surface - ticking over in 3rd slowly increase revs and without straining the engine it seems like something is twisting out of alignment and applying a brake to the transmission?)....ignore that comment don't even what to think about that - just the checking of flange wear - sounds exciting. will I need any rubber gloves Last edited by Caterham on 24th Jun 2015 3:24pm. Edited 1 time in total |
The transfer box is actually a very simple component. There are copies of the overhaul manual available online (for example here), and although there are several variants of the basic LT230 they are all pretty much the same. To understand how it works it doesn't matter which manual you use.
If you download yourself a manual you'll see what I am talking about, and have all the knowledge to carry out a full strip down and inspection. |
thank you. more bed time reading........
and more nightmares. |
Sorry, where did "flange wear" come from? Do you mean wear on the selector sleeve and hub? If so, you strip the transfer box completely and inspect the relevant components. |
Sorry hub.
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Aha, so this is why my ears have been burning!!!
Partial engagement by yours truly was the cause of the additional backlash and also why the transfer box jumped out of gear while under power as I pulled pretty smart-ish out from a junction. To put it simply the selector shaft was not fully engaged in the detent. I recall the vehicle was virtually new at the time and the ratio lever quite stiff, component wear or non factory adjustment did not enter the equation. I have delved into enough Land Rover transfer boxes over the years and they are simple enough to understand, bar fluid checks and changes all the ones in Puma's I've owned have remained virginal when it comes to any delving on my part though Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Thanks Steve
