![]() | Home > Technical > SVX front indicator lamp connector |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6691 ![]() ![]() ![]() |
No photo?
Fiebre Member Since: 24 Jun 2015 Location: Sabadell Posts: 25 ![]() ![]() ![]() |
Foto added...
If it is the two black rectangular connectors in the left hand corner of the bag then they are 2 pin econoseal connectors. Can not remember if that is the male part or the female part without going to look.
If you need any send me a pm with details and I will see what I can sort out for you. Brendan |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
One end is a 2way Male Econoseal and the other a 2way female Junior Power Timer or Packard Timer Connector. See Here:
http://polevolt.co.uk/acatalog/info_10802.html http://polevolt.co.uk/acatalog/info_20910.html http://polevolt.co.uk/acatalog/info_ESC2M.html Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks a lot for the info
AndyW Member Since: 01 Apr 2016 Location: Norfolk Posts: 4 ![]() ![]() ![]() |
I presume it's the Juinor Power Timer / Packard connector that attaches directly to the indicator unit, but would I need a male or female variant - depending on part manufacturer they all look different as far as the internals are concerned!
![]() If anybody could also advise which connectors fit the SVX front spot lamps I'd be most grateful. ![]() Great forum by the way guys, some really knowledgable people on here. ![]() |
Hi Andy,
Have you got a photo of the back of the SVX lamps. I'm not familiar with them but a photo will help track down the correct connector to use ![]() ![]() ![]() |
