![]() | Home > Technical > rpm and temp gauge stay locked when turning off |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
just something to consider - the day counter (odometer) resets to 0.0 when the battery is disconnected.
could it be the fuse that provides the constant feed is blown. sorry no idea about the gauges tho ? do you by any chance have a scangauge or anything similar plugged into the OBDII - or so try disconnecting it. |
Penguin Member Since: 08 Dec 2014 Location: Tienen Posts: 247 ![]() ![]() ![]() |
good luck.
