![]() | Home > Puma (Tdci) > Limp mode / Ultragauge |
| yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200
I have the following situation today, just after starting the engine:
Tachometer dead Temperature gauge goes immediately to maximum Battery charging illuminated (other gauges show the battery charging normally) Drove few miles, realising I am in limp mode. Quick look at Ultragauge - it was trying constantly to connect (scanning), while it should be on. I have checked all the fuses and only after disconnecting Ultragauge the engine started normally. After re-connecting Ultragauge it scanned the port and started normally. Re-stared engine worked normally. Is that possible for a ODBII scanner to send "wrong" signals that may cause such failure or shall I look for the reasons beyond Ultragauge? In few weeks I leave overland to China and back - knowing the cause will help me to keep peace of mind. Cheers! Janusz www.yahodeville.com |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
| LoveB Member Since: 15 Apr 2013 Location: Uk Posts: 38
Gotta let it load before you start it
Seems to be not fully clipped connector to the instruments clusters.
Clipped and fixed. Thanks for the hints www.yahodeville.com |
