Home > Other Site Sponsors > [For Sale] RHD TruckLite LED headlamps 27291 PHASE 7 £ 250. |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Got mine today Hopefully I shall find time to fit them tomorrow.
22nd Jun 2015 5:11pm |
TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 192 |
please post some pics then
22nd Jun 2015 5:29pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 546 |
Got mine today as well! Thank you! 2005 90 XS
1954 86'' Series 1 tilt |
22nd Jun 2015 6:54pm |
JJbing Member Since: 02 Dec 2012 Location: York Posts: 41 |
Could you gentlemen please upload pics when you can?
23rd Jun 2015 9:37am |
If you put 'Defender Trucklite' into Google Images there are as many as you could wish for. If you go through life with your head in the sand....all people will see is an ar5e!!
23rd Jun 2015 9:43am |
Aye, but it is good to hear a forum members experience of fitting and opinion etc...
23rd Jun 2015 9:48am |
But it was just pictures you asked for? Never mind. I do not have trucklites but have tried two other types of aftermarket LED headlights. Fitting is easy. Remove indicator and sidelight, two screws each and disconnect. Remove a further two screws for the light surround panel and remove. My manipulating the light you will be able to remove it from it's securing/adjusting points without undoing any further screws. Electrically disconnect the single connector and you will then see how to remove and refit the bezel from the old headlights (if required) to the new lamps. Fitting is the reverse. Any LED upgrade is better than none and as the Trucklite also has the highest IP rating it is in my opinion and experience an excellent choice as the IP rating is the most important factor. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 23rd Jun 2015 10:01am. Edited 1 time in total |
23rd Jun 2015 9:57am |
As a bit of a novice with electronics all the help I can get is welcome, thanks for your help K9F
23rd Jun 2015 10:00am |
Welcome. Initially once the panel is off do not undo any further screws as two of them are for level adjust. You should as stated be able to manipulate the light out as they are retained by the bezels that have slots that the screws go into not holes. I just swapped the lights out and no further adjustments were required once fitted. Hopefully it will become clearer when you see it.
The holes you see at 2 and 8 o clock are the small clips with screws that hold the light in the ring. You swap the ring over once the light is removed. The slots at 12, 3, 6 and 9 are what hold the assembly to the truck, two of which will be levelling adjustment screws. Hope this helps. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
23rd Jun 2015 10:10am |
Finally fitted only took a few minutes
Click image to enlarge Click image to enlarge When it's dark I shall get a few more pics but alignment will have to wait until she is off the axle stand. |
23rd Jun 2015 6:55pm |
Not great because beam alignment needs sorting and wasn't very dark but initially looks f awesome
Click image to enlarge Click image to enlarge All I can say is thanks to nakatanenga crew for an awesome deal and rapid shipping Okay it appears I have come over all Australian in my last post, now how do I sort this?........:sorted |
23rd Jun 2015 10:44pm |
Looks great
24th Jun 2015 2:20pm |
DOOFER Member Since: 07 Oct 2012 Location: Suffolk Posts: 412 |
looking good, still waiting for mine, DON'T PANIC
24th Jun 2015 7:08pm |
Redlinemike Member Since: 27 Oct 2013 Location: Frozen north, Just off the M8 Posts: 93 |
are these still available? 110 XS DC M57 + 8 Speed auto
ORA jeep- Sold Tomcat 88 |
29th Jun 2015 2:49pm |
