Home > Technical > Rear interior trim removal...
YOLO110
Australia
Hi Guys and Gals,
Help please!
I have an MY14 Puma 110 and want to remove the rear trim panels around the windows to fit Panoramic glass. When I removed the small plastic covers over what I thought were going to be screws or fir tree's just inside the rear door panel and along the top of the panel, what I can see under the caps look like rivet heads!
Has JLR started to fasten these panels with rivets... which will mean I will have to drill them out? Or are these just press stud fastenings that will pop off with a bit of leverage? I don't want to crack anything!
Any ideas please!
Cheers, Pete Smile YOLO... You Only Live Once...
Post #432709 22nd Jun 2015 3:37am
YOLO110
Australia
57 views and no ideas? Shocked YOLO... You Only Live Once...
Post #432776 22nd Jun 2015 11:54am
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
Sorry, but I can't help other than suggest that since its a 2014 model, you take it along to your friendly local dealer for his advice.
Mine's a bit older and the rear interior trim is 10mm plywood which comes off with a screwdriver bit in a battery drill. Simples! Smile
Best of luck. Thumbs Up --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #432778 22nd Jun 2015 12:00pm
YOLO110
Australia
Cheers mate! Yes, screws were what I was expecting to find given what is noted on the 'net'!
Oh well... I guess a trip to my local dealer will indeed be the next step! Wink YOLO... You Only Live Once...
Post #432784 22nd Jun 2015 12:13pm
mk1collector
If I'm understanding what your saying you mean the trims for the two small windows next to the rear door. If so under the small caps there should be rivets but these don't need touching. Just grab the trim panel close to the rear door and pull it towards the front of the car and it will come off as the clips that hold the trim on just push on. Ray
My build thread
Post #432805 22nd Jun 2015 12:58pm
gilarion
The rivets you are referring to hold the spring clips to the trim, whatever you do don’t drill them out! The side trims are held by spring clips along the top edge so you should be able to manoeuvre the trim out once you jiggle it a bit to release the clips you should have fir tree fasteners on the bottom of the trim. The trim is held in place by a combination of fir tree fasteners and clips. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #432806 22nd Jun 2015 1:04pm
Does this help:
Removal
1. Remove rear bench seat. For additional information, refer to: Rear Bench Seat (501-10,
Removal and Installation) /Third Row Seat (501-10, Removal and Installation).
2. Remove rear quarter trim panel. For additional information, refer to: Rear Quarter Trim Panel (501-05 Interior Trim and Ornamentation, Removal and Installation).
3. Prise finisher cap from rear seat belt upper guide bracket retaining bolt.
4. Unscrew bolt and remove guide bracket from 'C' pillar.
5. Remove bolt securing seat belt to wheel arch mounting.
6. Prise trim panel cap fastener from 'C' pillar.
7. Remove seat belt aperture finisher from side trim panel.
8. Remove screw and release seat belt clip from 'C' pillar.
9. Remove fixings securing bottom edge of trim panel to body side.
10. Release top edge of trim panel by striking upwards with the hand to disengage 3 spring clips.
11. Lift trim panel from window surround and feed seat belt through panel aperture.
12. Remove trim panel from vehicle.
Rear Quarter Trim Panel Removal and Installation
Removal
1. Pull edge of rear quarter trim panel firmly to release 2 spring retaining clips from vertical rail at door aperture.
3. Remove spring clips from the 2 brackets on side of trim panel.
Post #432809 22nd Jun 2015 1:25pm
gilarion
This might also help with the removal and fitting
http://www.vehicleglazingspecialists.com/p...guide.html For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #432818 22nd Jun 2015 1:58pm
YOLO110
Australia
Perfect!!!
Many many thanks for the replies... Thumbs Up
Post #432933 22nd Jun 2015 10:54pm
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Having removed the rear trim panel to fit a ladder can anyone advise where I can buy replacement spring clips from?
Post #535261 27th May 2016 8:31pm
mk1collector
Post #535267 27th May 2016 8:38pm
Keith5
Thank you
Post #535929 30th May 2016 6:26pm
ericvv
Post #535932 30th May 2016 6:35pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Supacat ,on the second diagram , do you a part number for the 3 screws/fixing ? And can these be replaced with the fir tree clips EZM100340LOY .
Post #673632 27th Dec 2017 6:49pm
donmacn
Holy thread revival!
Yep, I know this one dates back a few years, but it's what google pointed me to.....
I've had my car for something like 19 years, and never had the rear quarter trim. It didn't come with a set, but I've now got some.
I can see that I need the clips (referenced above) to attach the trims to the door frame. BTR6682. I found one of them attached to the car after all the years. I can get more of them. No problems.
But..... how does this trim panel fit / connect to the side window trim? I haven't any photos to hand - which would certainly help - maybe tomorrow. There seems to be a sprung 'leaf' bracket attached to the rear quarter trim, but as far as I can see, nothing for this to link / connect to on the side trims.
I guess I must be missing something?
Or.... they are meant to just 'tension' or 'brace' themselves against the side trims, and be fixed into the other clips?
I know this is quite hard to describe, but if this has made sense to anyone else, please let me know what you can.
While I'm on the same sort of subject. My side trims just have the 'big' hook/clips, which I assumed were just meant to hook onto the internal guttering. Now I see on the parts diagram that there are smaller versions of the clips above - MWC6203 - are these supposed to clip onto the guttering, and have the trims hook into them??
Thanks as always. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #824885 12th Apr 2020 10:52pm
