- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Mine goes under the bonnet, it does indeed foul the bonnet as MOG suggested if bonnet is not adjusted properly.
In my case the hinge bushes were worn dropping it but about a mm causing the two to touch.
Since adjustment and new hinge shims all is good and a mminor paint touch up.
I'd rather it this way than having a gap with dirt in it, every time you clean up you'd have to open the bonnet and that'll cause wear in its self.
21st Jun 2015 2:32pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
