![]() | Home > Technical > hi lo revs switch |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
one thing I hadn't realised until recently about the idle jack (which is the feature you're talking about) is that it doesn't have a switch telling the ECU you're in 1st or reverse. It just guesses you are based on the engine revs and forward speed.
Exactly, which is the recently I was referring to
Just thought I'd pass that on |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
tightened the earth on the battery the other day and all seemed good but now
rev counter is waving up /down. not a lot but clearly it's not right. also getting the clatter sound which I'm assuming is the result of a poor electrical signal but why o why o why ? |
Just tried the hi/lo again after removing the plug on the side of the transfer box (not sure if it was hi/lo or diff lock).... Anyhow tried the hi/lo and in low in 1st no increase in revs while clutch depressed.......and slowly released....and then increased for a bit fluttered about and then went again and can't get them to increase again eight in first or reverse?
Any ideas? |
I think what I unplugged because was the speed sender - but not sure?
Is the hi/lo switch accessed from above ie cubby box out? |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
The speed sender is behind handbrake drum down the bottom
Thanks Munch90 - so it was the speedo.
Need to get to the top I presume for the hi/lo? Cheers mate. |
Might be worth checking one of your posts , check your rods or something , think it may be the one in your own pic
sorry dont know 100% , as never played with switch |
Hmm good thinking...
I think the link rod changes position of get lever and doesn't impact on the switch ( but not sure) |
Yes , but in the pic , you can see a switch
eBay Item No. 111646389017
Hi lo switch |
Thanks Munch90. Will go have a look shortly.
| pumaxs Member Since: 18 Jul 2012 Location: Bath Posts: 180
That's interesting. I drive the 'Spaniel Taxi' in low range on a daily basis. On mine, the revs do not pick up as soon as either low 1st or reverse is selected. Having released the clutch, with no throttle input, revs have picked up to just over 1k rpm after travelling approximately 5 or 6 feet. Not an exact measurement - I just lined the front mud flap up with a dandelion Am I normal? |
hi/lo switch now disconnected, so will see how it goes later?
