Home > Maintenance & Modifications > 230V inverter installation
Caterham
can anyone recommend an inverter and installation
I'm looking to install one - nothing too big c300W probably in the rear?
anyone done this already - any pros / cons?
Post #43243 21st Oct 2010 8:49pm
--defender--
United Kingdom 2010 Defender 110 Puma 2.4 HT Zermatt Silver
Any inverter will sap the vehicle battery before you know it, I'd install a 2nd auxillary battery fed from a split charge relay. This will ensure you've plenty of juice to start your engine.
Post #43245 21st Oct 2010 9:07pm
Caterham
surely a 300W jobbie would be ok for an hour or so ?
Post #43246 21st Oct 2010 9:15pm
Laurie
300 watts would see a new diesel battery unable to start the engine in 2 to 3 hours.
Post #43248 21st Oct 2010 9:23pm
Caterham
oops - i thought the batteries were rated about 200A / hours (obviously not?)
Post #43249 21st Oct 2010 9:38pm
AndrewS
I have a 1500w inverter in J-Lo its mounted over the rear wheel arch. Its connected to 3 battery's that are placed under the 2nd row seats. 130's have feeling's as well you know Smile
Post #43250 21st Oct 2010 9:45pm
Laurie
Where do you get yours!
I think mine's about 90A/H and it wouldn't do much with only a third charge left in it.
Post #43251 21st Oct 2010 9:47pm
leeds
A 300 watt inverter would draw about 28amps at full power, so at full power you have 2 to 3 hours on a standard battery. We use our inverter whilst driving so we don't run into the flat battery syndrome.
The inverter runs off the second battery hence protecting the main starter battery. The split charging system also has an audible low battery alarm.
HTH
Brendan
Post #43252 21st Oct 2010 9:49pm
Caterham
thanks guys
so an inverter for on the move or a split battery jobbie.
Post #43253 21st Oct 2010 9:52pm
leeds
Twin batteries or inverters?
Really depends on what you need from your vehicle?
If you intend running a fridge/auxilary lights etc then twin batteries are good.
If you want to just charge your laptop up whilst on the move then an inverter is fine.
If you are planning on equipping vehicle for overland trips then you might want both a twin battery system and an inverter.
What are you planning to plug into the inverter? Could you get away with a 12 volt adapter for whatever equipment you are going to plug into the inverter?
Brendan
Post #43265 21st Oct 2010 10:51pm
Eduardo
I will install a 1500W inverter + 2 deep cycle batteries in our folding camper and an isolator to prevent to drain the car battery when are hooked-up. As we will probably spend a lot of time camping without electricity for this reason this setup.
A nice formula to see how much time is needed to drain a 12V 100Ah battery is as follow:
Time in minutes = 11609 x (current in Amp) ^-1.3269
So, if you have, let said a 300W consumption means 300/12 = 25Amp
T = 11609 x 25^-1.3269 = 162 minutes
A 800W hairdresser can last your battery in just 44 minutes, and so on. Eduardo
Post #43271 22nd Oct 2010 2:27am
